Rev Counter help on Mk4 Escort/Mk2 Orion
Old 01-12-2015, 10:58 AM
bassboy
bassboy's Avatar
Default Rev Counter help on Mk4 Escort/Mk2 Orion
Hi everyone, I know this has been asked a million and on times and I have used the search function but nothing seems to be of relevance and anything that is covered which is similar, was never answered fully...so here it goes
I have a base spec 1.3L OHV Orion and sourced some xr3i/rs turbo clocks to install.
The plugs were different in the car so I have sorted that problem out by using the later spec plugs and re-wiring the pins.
Now, the rev counter I have connected it to the Edis module (I think lol), and all the previous questions, the replies are always use the green wire coming off the coil. My coil is located at the back of the block and looks more like a coil pack than a distributor and has a plug with three leads going in - green/yellow, green/red and black. These run back to the Edis module so I simply chose to tap into the wire near the module as per pic
Please ignore the lack of insulation tape and heat shrink etc
I have tried both the green/yellow and green/red but the rev counter either reads half of what it should and doesnt really rev above 2k
I also found someone mention to adjust the knob on the rev counter dial but this has made no difference.
What am I doing wrong? Do I need EFI dials?
Ultimately it will be going Zetec so im not too wrapped up about this, but ideally for now, I would like to get it working as it should.
Thanks for any help
If you need me to take a video of the rev counter to show what its doing, just let me know
Old 02-12-2015, 06:49 PM
bassboy
bassboy's Avatar
Anyone?
Old 02-12-2015, 07:18 PM
mk2grp1
going sideways in a fwd
mk2grp1's Avatar
pin 2 is correct there is a tiny allen key behind the rev counter to set resistance
or yes get an efi rev guage
Old 03-12-2015, 12:03 PM
bassboy
bassboy's Avatar
Thanks for your advice, ill try sourcing an EFI clock set. Like I said, I did try adjusting the screw/allen key, however, it made no difference in my case unfortunately.
Will let you know how I get on
Old 03-12-2015, 12:12 PM
djmca
Bring back old skool Ford
djmca's Avatar
Sorry to jump in but i have the same problem for my MK3, im running the Zetec with the silver ESC module but it only reads half revs.
Any suggestions on how i can fix it? Ive tried a diode as shown when you google it but that didnt work
Thanks
TeemuP
13-11-2015 02:56 PM
Erstdeano
11-11-2015 08:58 PM
InFlammen
10-11-2015 10:23 PM
Craigsteen rs
03-11-2015 08:24 PM
bailes53
03-11-2015 05:10 PM
Quick Reply: Rev Counter help on Mk4 Escort/Mk2 Orion
