Diagnose problem plz
I'm having a lot of noise from drivers side wheel also clicking when I turn so jacked car up,the wheel has a lot of 9-3 movement but no half twelve movement,the driveshaft popped out a while back just pushed back in ? But the driveshaft now has a lot of movement all new track rod ends lower arms what is causing this to move so much as driveshaft not doing it on passenger side cheers forgot to say that the ball joint on lower arm is hitting back of disc there's that much movement which I think is causing the noise at speed
Think it could be hub carrier as I can turn the driveshaft by hand quite a lot any idears cost to replace this with labour car is frst cheers
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
