St220 humming noise
Old 03-08-2015, 04:50 PM
malkiemac3579
malkiemac3579's Avatar
Default St220 humming noise
Hi all
New on here and hoping for some advice.
I have a model ST220 2003. Petrol 3.0ltr.
I have a noise from front which sounds like a wheel bearing but isn't as both have been replaced as have the discs and pads. I have also just replaced both tyres. Noise is prominent and defiantly in drive train somewhere. At speed if you dip clutch noise persists which would suggest it's not clutch related or perhaps gearbox related....any thoughts?
Old 03-08-2015, 06:28 PM
gcfcos
gcfcos's Avatar
Is there a driveshaft bearing on the front? Normally fords have it on the o/s/f driveshaft (the longer one) halfway down the shaft, I know some fords used to suffer with that bearing wearing and getting noisy, not sure if the mondeo has it though
Old 03-08-2015, 06:36 PM
malkiemac3579
I haven't checked...it definately seems like it's osf in fact right under my feet..I thought the fact brakes were metal to metal was the cause only to road test and damn hum to still to persist
Old 07-08-2015, 11:20 PM
gcfcos
gcfcos's Avatar
Any luck?
Old 01-05-2016, 10:09 PM
Mondy Focus
Mondy Focus's Avatar
Nobody has ever posted a solution to this humming , spoke to a mechanic and
the intermediate bearing on driveshaft is mentioned but nothing definite.
Still seeking a solution after 4 years on 2.5L v6 engine.
Old 20-07-2016, 09:35 PM
Mondy Focus
Changed intermediate bearing on the driveshaft and still hums having done both wheel bearings and new goodyear tyres .i suspect the gearbox bearings.also changed gearbox oil.
Old 23-07-2016, 03:22 PM
richard youll
richard youll's Avatar
Noise coming from front or rear? It isnt the moosing problem is it?
Old 23-07-2016, 05:33 PM
mark826
mark826's Avatar
Could well be the diff bearings. Although after 4 years you'd have expected them to have shit their selves already.
Is the noise rev related or road speed related?
Old 23-07-2016, 09:09 PM
Mondy Focus
It hums at 20mph in gear and in neutral, rear wheel hub bearings both renewed seemed
to improve with new tyres on front but after few miles hum returned.
Revving makes no difference or different road surfaces,just at 20 mph front
end engine hums to vibrates.
Not moosing
Old 24-07-2016, 06:58 PM
Matt Cooke
Matt Cooke's Avatar
Any decent mechanic could diagnose that in 10 mins mate the bearings are easy to check and there are only 5, tyres for castleation then that leaves cv joints or gearbox, get it on a ramp and run it up in gear I've changed drive shafts on them for vibration
Mondy Focus (24-07-2016)
Old 14-07-2017, 12:10 PM
Mondy Focus
Update on Humming at 20 mph,problem solved had wheel alignment and the toe-in
was needing adjustment ,now drives like a dream.
gingeRS
17
02-10-2015 09:42 AM
Botts
22-09-2015 02:04 PM
pieterjan
Ford Focus RS
17-09-2015 06:17 PM
Si B
12-09-2015 06:49 AM
rsturbo27
05-09-2015 05:08 PM
Quick Reply: St220 humming noise
