don't look like i'll be going to ford fair, car's given up, help!!!
Old 31-07-2015, 06:08 AM
sridgett
The only way is dagenham
sridgett's Avatar
Default don't look like i'll be going to ford fair, car's given up, help!!!
Can someone help me please, I was surpose to leave for England at 2 am this morning. Got in my mk6 escort, put the lights on, thay came on and then all of a sudden all the eletric's went out. I can still start the car but have no lights, hazards, radio, interior light, hight beam and rear lights apart from the fog light.
Cheers all
Old 31-07-2015, 06:19 AM
Fordmad!
Fordmad!'s Avatar
Sounds like a fuse box issue. Take it off and dry it out and re fit it see what happens.
Old 31-07-2015, 06:26 AM
Moderator
STeve's Avatar
lighting issues on mk6s are normally always stalks as they control the lot, radio and int light is normally a seperate fuse
Old 31-07-2015, 06:34 AM
sridgett
sridgett's Avatar
Yeah we're gonna try this. Cheers
Naa all the fuses are good. I also have break lights and reversing lights. I noticed too the clock has stoped.
Old 31-07-2015, 06:40 AM
Moderator
STeve's Avatar
clock radio and int light are normally all on one fuse, but I suspect your stalks are the main cause, simply keep turning the lights on and off wiggling the stalk switch as you do it because even if they flicker it prooves its them or get a multi tester on it and see if its doing its job, mega common fault
Old 31-07-2015, 06:44 AM
Fordmad!
Fordmad!'s Avatar
Or take stalk off and clean contacts had this before
Old 31-07-2015, 07:19 AM
sridgett
sridgett's Avatar
It is the fuse box. Now to fix the bloody thing
Old 31-07-2015, 07:49 AM
Moderator
STeve's Avatar
mk6 fuseboxes are normally very good as the mk5s were well known for faults, you are unlucky fella
Old 31-07-2015, 08:04 AM
sridgett
sridgett's Avatar
It's looking that way yes lol
Old 31-07-2015, 08:20 AM
sridgett
sridgett's Avatar
Yeah we took it apart and the box is pissed through. Hopefully we can dry it, and there is another ferry tomorrow. Hopefully i'll be on it.
Old 31-07-2015, 08:22 AM
Moderator
STeve's Avatar
make sure youy seal up wherever the water is getting into the car or it will be pointless
Old 31-07-2015, 08:28 AM
sridgett
sridgett's Avatar
Yeah sure will mate, it's a bloody good job it happened it the drive
Old 31-07-2015, 10:27 AM
gcfcos
gcfcos's Avatar
Good luck matey!
Old 31-07-2015, 10:34 AM
andrew capstick
andrew capstick's Avatar
good luck with your fix,and your journey.
Old 01-08-2015, 04:48 PM
Fordmad!
Fordmad!'s Avatar
Thought it would b the fuse box min scuttle panel had rusted so it was screen out to repair it :/ I put a plastic bag over fuse box now just in case
Old 03-08-2015, 07:26 PM
gjh
gjh's Avatar
Spoiler alert maybe but he made it!
The Underdog
29
07-09-2015 09:49 PM
Billy_RS
15
05-09-2015 12:04 PM
UncleDezza
20
23-08-2015 08:08 AM
Versus_Creations
24
05-08-2015 09:32 PM
Quick Reply: don't look like i'll be going to ford fair, car's given up, help!!!
