Focus Zetec s problems
Hi my 2009 Ford Focus Zetec s 1.8 petrol has a misfire problem and also seems to lack power in higher gears. When accelerating on a motorway it seems very sluggish and often is like a kangaroo in the way car jumps under acceleration. Had recent service including correct plugs. Car done 61,000 miles
Any ideas on fault? Took it to garage twice and both times been fine for them and no recorded codes
thanks for any help
thanks for any help
not sure on these newer models but coil packs and leads are quite fragile on the older Zetec engines.. Not that expensive to replace as a test or find a friend and swap the coil packs over.. 20 min job to rule it out..
2p
2p
2wdsaph ben (28-07-2015)
Hi thanks for help, I have tried branded fuel and didn't notice any difference.
The garage did suggest renew coil packs and leads but they said it might not mKe a difference. I think I will get them fitted and see. Thanks
The one on my old fiesta zetec s had the car from new,only managed to last 17k on the genuine ford one. Replaced with after market one had 68k when traded it in never missed a beat.
