Don't you love a cheap fix
Had a clunking sound coming from what I thought was the CV joints and it had been getting worse and worse. Finally had time to inspect and it turn out to be the rivets that hold the ball joint onto the lower arm had worn on both sides. The ball joint was fine, so I cut off the rivets and replaced with nuts and bolts. Changed the car completely, it's now a joy to drive again. Result
Result!
Thought I had similar where the battery light was flickering on and thought it was the alternator turned out to be the wire from alternator to battery where the connector was to go on to the terminal it had gone rusty and had fallen apart a new connector and sorted
I had one of these today!!
What I thought was the diff on my Mondeo was getting noisy. It was making a horrible typical fucked box sounding whine at 2500rpm and got noticeably louder when going round roundabouts. Thought it had to be the diff?
Anyway I was under the bonnet the other day and noticed the power steering fluid was frothing over out of the reservoir all over the fooking floor. Did a bit of looking about online, turns out its common for them to block the filter inside the reservoir. Bought a new one from Ford and fitted this morning, foaming has stopped, cured all the whining too. Turns out it was the power steering pump whining and not the gearbox lol. Quite lucky I didn't get the box out for a rebuild!!
Exactly what happened to mine. Only the new res didn't work
When you fitted the new reservoir, did you take the green gauze thing out of the bottom outlet? It seemed to be totally blocking the flow from the tank, after fitting it I had no PS at all until I took the tank off again and junked this bit that wasn't in the old one!
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
