just had my fiesta mapped by devil developments 518bhp
Just got my car back from lee at devil developments after a few tweaks to the map after fitting a precision turbo 6266gen2.to say ime happy is a understatment. So a huge thanks to every one at devils and this should keep me entertained for a while
What turbo is that the , it looks like it is over 4000 rpm before it begins to rock n roll or is that designed in to aid traction on the light car?
Cool, I bet it is ballistic
Mental fair play! Will be pretty nippy then!
Jesus rob that must be mental. fair play to ya
hi rob well done mate i know you always wanted to break the 500bhp barrier and its nice to see my old car built up and alive again. i personally wanted to do this but after fitting the 300bhp engine in i thought that was a handfull , your gonna have your work cut out thats for sure.
why did you change turbos mate and what boost did you run to get 518 bhp
cheers paul
cheers paul
Its got more power than the trolly as luca is only running 508bhp on high boost and ive geared the box so it should be able to beat the 184.9 but i need to sort some aero aids out to keep the car handling propely
The turbo is doing 1.9bar paul.i changed it as the old one was struggling to make the power
Very nice mate
Under the car...!
Wow.
This gives me inspiration again for my dragging project!
What a beast.
What sort of spec is the engine? Is it dry sump or not?
nice job. Video needed!
What a beast.
Spec of the engine is
Area six bigvalve.double valvesprings. Fully ported head
Area six ultimate cams
Farndon rods
Accralite pistions
Area six inlet
Custom 321stainless areasix exhaust manifold
Precision 6266gen2 turbo
Full drysump kit
Pectel t2 ecu
For me to get any more power i need to change the boost pipes to 3" ones and get a bigger tb but ime happy for now
Farndon rods
Accralite pistions
Area six inlet
Full drysump kit
Pectel t2 ecu
Well done mate, lee is a very good chap, mapped our motor in the track car, we have given it 2 years of hell and it ain't missed a beat, might be back down there again soon for a tweek.
Under the car...!
Farndon rods
Accralite pistions
Area six inlet
Full drysump kit
Pectel t2 ecu
Farndon rods
Accralite pistions
Area six inlet
Full drysump kit
Pectel t2 ecu
My spec is similar but I don't have the inlet manifold or dry sump kit!
Do you mind if I ask what kit your running? What sort of cost are they?
The chances of the boost pipes and throttle body limiting power is very slim.
A friends Subaru made well over 600hp on 60mm OD pipes and standard throttle body with the same turbo, and only the small 3"/2" compressor cover.
Wind some more boost into it, water/meth injection and it'll make a lot more power as is.
What turbine and housing are you using ?
Farndon rods
Accralite pistions
Area six inlet
Full drysump kit
Pectel t2 ecu
Farndon rods
Accralite pistions
Area six inlet
Full drysump kit
Pectel t2 ecu
ime using a precision turbo 6266gen2 with a .63 housing. Also have a .82 if its needed later on
If it's a T3 housing which it almost sounds like, then moving to a larger A/R would be quite sensible to make more power, and relatively cheap.
Of course it may impact spool..or it may not.
Always worth trying
Always worth trying
Mark_
40
02-10-2015 04:40 PM
