Rear brake hub to disc conversion
Hi everyone.
I'm just after buying a Sierra staff 2000e and was wandering is converting the rear brake drums to discs is a big job and what parts would I need
thanks.[U]
thanks.[U]
As above, i swapped drums to discs once, was on an estate so swapping axle wasnt that simple, but the splines on the shafts were differant so needed to change them, but the the inner joints didnt fit the original diff flanges so ended up swapping diff as well,
Wasnt a big deal as i had everything anyhow, but just be warned that you may need to change more than you think, so easier and faster to swap over the complete axle
track.focus'd
12-08-2015 05:53 PM
