Disabling Start/Stop more permentantly?
My new Focus has the stupid start/stop system.
I've always started my cars and left them idle for 30s to a minute prior to driving to ensure oil has gotten everywhere required and always given turbocharged cars run down time or at least driven them gently for the last few miles or so to ensure the turbo isn't starved of oil when the engine is shut down. As a result you can probably see why I despise the start/stop technology.
I can't see how the engine shutting down seconds after you've potentially had the throttle wide open and then driving off instantly as the car restarts again will do anything for reliability. And I know about two weeks after the warranty ends I will press the clutch and the bloody thing won't start.
I know the start/stop can be disabled by pressing the button but I keep forgetting to press the button until the car has shut down at a traffic light.
Does anyone know if it can be disabled more permanently or even set as off by default on IDS?
Bailes.
Bailes.
Not necessary. I am sure the technical boffins at Ford know more about what is good for it than you (I don't mean to sound like a cunt lol).
Just get in and drive it. Leaving it on cold idle is doing more harm than good, the longer the engine is cold for the more wear that is happening. The quicker you can get it to operating temp by driving it normally the better.
If the battery is getting weak the start / stop will stop working and give you a message to say so.
I'm not convinced. Just like DPF's, I think they are just there to increase it's green appeal.
Surely starting the engine from cold 6 times prior to getting on the motorway is more harmful to the car than the engine idling for 3 or 4 minutes at traffic lights.
My Father's F30 320d is the same and the turbo is starting to get loud after just 3 years and 77k.
I think if you just wire a capacitor across the 2 terminals of the switch,it will be "permanently" off.
The capacitor is a short circuit while it is charging,thus activating the switch..
Live long and prosper!!
Also imo increased engine ware due to oil pressure.
So you go to work and your stuck in traffic its cold and your fucking pile of shit diesel keeps stopping and never warms up so increased fuel economy.
what u have saved in tax will go.on fuel,starter motors,batterys.
Those boffins know how to make money.
On my Merc the stop-start isn't active till the engine is up to operating temperature (which doesn't take long), and it doesn't operate if the outside temp is too low, or there is too much electricity being drawn (by lights, wipers HRW, AC etc).
I wouldn't worry about it.
Received 1,042 Likes
I can see a lot of starter motor and battery failures.
On a cold winters day you warm the car up then sit in traffic,the stop start kicks in and your sat in the car with cold air blowing through the heater.
I work in a main dealers and were already getting 3 year old cars in for the stop start battery's to be replaced but considering there potentially used just for starting the car loads of times 3 years isn't horrific. Starter motor wise we haven't changed one yet. The main problems we get are with dpf systems. With the Mitsubishi diesel range shoguns/l200s and outlanders it's either in for egr or dpf faults or clutches. And that's constant every week too. Utter shite. Apart from the battery's we haven't seen a prob with the Mitzi or Mazda start stop systems yet
Yeah your not wrong mate. The mitsubushis are terrible, they come in for just a simple service and end up being here for 2 days doing a mild restoration lol :-( got one on the ramp at the mo a shogun and it came in for oil and filter change and health check. Ended up doing timing chain tensioner and brakes all doing, both front calipers are fooked (£££££ each!!) same with every one that comes in. The mazdas are normally much better but the Mazda 6 diesels are littered everywhere with fooked bottom ends and the petrol turbo cx range are always coming in pluming out smoke with duff turbos after like 20,000 miles!!
I had a bm with the stop start, got into the habit of knocking it off when I started up.
it wouldn't cut in until the engine was warm, and also not if the battery was low, or would automatically fire the car back up if sat for a bit with all the toys on.
I personally would guess it is one of the reasons bmw have all the timing chain issues , as said, stopping and starting dozens of times a day compared to maybe 2 or three times on an average day.
Mazda Man
24
01-10-2004 08:52 AM
soulweavers
Computers, Consoles and I.T.
01-08-2004 09:03 AM
