MT75 4x4 Gearbox Output Shaft
Old 28-02-2015, 09:42 AM
McCloud 85
McCloud 85's Avatar
Default MT75 4x4 Gearbox Output Shaft
Quick query on the output shaft on my 4x4 box, from looking at the build diagrams am I right in saying there is a small shaft that fits to the mainshaft of the gearbox that holds the drive flange? If so can this be easily replaced with the box in the car?
Some swine has cut my shaft down to fit the earlier hex rubber doughnut rather than getting the correct front end of the propshaft and the newer thinner doughnut. As the hex doughnut is knackered I have had to replace it with the newer style and matching prop but the shaft will not centre properly as the gearbox spigot has been cut !
So can this part be replaced easily or do I fear the worse and the gearbox is coming back out again...
Thanks
Dan
Old 28-02-2015, 03:19 PM
The Youth.
The Youth.'s Avatar
yes you have to take the rear transfer box section off the car (about 15 bolts) undo the 2 rear gear cradle mountings then remove from the gearbox, then take out the VC, then just knock it out and replace
steve
Old 28-02-2015, 04:42 PM
McCloud 85
McCloud 85's Avatar
Ok great, I'm assuming you need to remove the driveshaft flange first? The only reason why I ask is I've seen photos of the transfer case with the flange and shaft still in place.
The bext question is where to get the shaft from? CTS wouldn't sell one unless the gearbox went to them and they fitted (which I can understand) just means I have to take the gearbox out which I'm trying to avoid and the journey to them!!
Old 28-02-2015, 08:25 PM
The Youth.
The Youth.'s Avatar
yes the flange is held on with a big nut 36mm I think, you will need a long reach socket and an impact gun is best to get it off
to be honest the chew you will have doing it its just as easy to drop the gearbox
steve
Old 28-02-2015, 10:22 PM
McCloud 85
McCloud 85's Avatar
Ok many thanks for the replies/advice. Looks like I have a nice Sunday morning planned!
Old 02-03-2015, 05:58 PM
McCloud 85
McCloud 85's Avatar
Does anyone know where I could get one of these shafts (late spec) from? Other than CTS.
Thanks
Old 02-03-2015, 08:25 PM
The Youth.
The Youth.'s Avatar
Thanks
I'll have a look mate, I blew a gearbox up whilst racing In 2012 and I've got most of the bits in a box will look to see if its there
steve
Old 02-03-2015, 08:47 PM
McCloud 85
McCloud 85's Avatar
Many thanks steve
IainRS1700T
25-09-2015 06:44 AM
Bransby
11-09-2015 09:12 PM
morg65
Escort MK 5 / MK 6
11-09-2015 01:55 PM
rsstav
07-09-2015 04:43 AM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: MT75 4x4 Gearbox Output Shaft
