Zetec turbo build- what else do i need?
Kapow!!
Im doing a turbo conversion on my mk3 fiesta xr2i 16v (1.8 silvertop)
So far i have got everything for the basic engine- and is pretty much all built and together
Full rebuild
Audi tt 1.8 20v turbo pistons
Forged rods
ARP rod bolts
Devil developments valve springs
Oil return welded into sump
I have a straight cut gear set and LSD that is almost together, and a Helix paddle clutch kit.
As soon as the gearbox is finished i will drop it all in the car.
Other parts i have already-
Omex 600 ecu and bare loom
Focus rs exhaust manifold and turbo, new turbo gasket and clamp
Focus rs decat pipe
Rover turbo inlet manifold, adaptor plate, fuel rail with injectors and throttle body
Oil pressure switch t piece for turbo feed
Breather blanking plate
Next on the list was turbo oil feed and return pipes and front mount intercooler (take it i can use an rs turbo uprated one?)
Please can anyone tell me, do i use the 2.0 cams or the 1.8 (105) cams?
Will the standard radiator do the job or shall i get an ally one?
Im guessing i will need an uprated fuel pump- any advise on what one?
And anything that ive missed or that i should bear in mind??
Thanks in advance!
Full rebuild
Forged rods
ARP rod bolts
Focus rs decat pipe
Thanks in advance!
I'm using standard rad on my xr2 which has been fine. I use a cossie external fuel pump with a facet red top feeding the swirl pot.
I'm using standard 2.0 cams on mine too.
I've got a 2wd cossie front mount cooler id sell mate.
Have you got any boost control? Would advise an ebc!
Are brakes and suspension up to job?
Wideband AFR gauge?
Wideband AFR gauge?
Under the car...!
Full rebuild
Forged rods
ARP rod bolts
Focus rs decat pipe
Thanks in advance!
Full rebuild
Forged rods
ARP rod bolts
Focus rs decat pipe
Thanks in advance!
I am using a Bosch 044 fuel pump for the new motor build and they are awesome. A Walbro 255 is a bit cheaper I think and more than up to the job.
As mentioned above, an EBC, wideband AFR is crucial as well.
Kapow!!
Cheers for the replies.
How much for the intercooler?
And what do you mean by ebc??
And ok, il get on the case for an AFR and how about a truboost boost controller?
Was thinking about the 044 pump too
Kapow!!
Take it this will do the job?
Any reason not to have 2 gauges instead of 1 that does both things?
http://pages.ebay.com/link/?nav=item...d=291197118672
Kapow!!
I have pm'd you! Cheers
Right, il order an AEM wideband AFR gauge, and omex has boost control function so i do just need the solenoid.
Had an issue last night. I got my short engine together- fitted the sump but when i turned the engine over, the crank hits the weld where ive had the oil return welded in!!
I can grind this back and will have to relocate it.
Is there any reason why i cant return it to the breather blanking plate??
