2.8 turbo technics engine advice
hello all,
could someone please tell me if there is any difference between 2.8 heads and 2.9 heads and are they interchangeable.
would there be any benefit for fitting them. possibly have a cracked head on mine.
need to decide the direction i am going on this as need it sorted asap.
any advice greatly appreciated.
thanks all.
thanks all.
tonysierra4x4 (20-12-2014)
2.8 heads are twin port and 2.9 triple port, big improvment to fit them but unfortunately although they will just about bolt on it's not as easy as that. The 2.8 cam is gear driven and the 2.9 chain driven so a special cam would have to be mad up, then if u got around that you would have to get your turbo manifold modified to suit the extra exhaust port.
why do you think you have a cracked head?
if you use stretch bolts for bolting the head down they stretch under boost causing head gasket failure. go to your local bolt supplier and buy 12.9 bolts and hardened washers, torque them down to the earlier torque settings. cant remember what the settings are.
you can fit efi from an early mk3 2.8 granada if you can find one.
lee2cossies (21-12-2014)
traditional tuning gives ok results, turbo 2.8 doesnt like a wild cam, so air filter, exhaust and a mild cam. after that you can up the boost but the bottom end wont hold together too long without forged pistons, h section rods, a v6 cosworth crank and bob type block which will require machining to fit. all in all stick with the std 200bhp and you will have a reliable engine with great driving characteristics.
thanks. to be fair to the engine currently fitted, it does make the car fun to drive, has plenty of power and is quite torquey. i would prefer a reliable set up so probably just get what i have sorted. the car will be used for driving, classic runs etc, as i already have another classic car for "playing" with.
all replies are appreciated as i realise time for everyone is in short supply.
Boost Junky
I had an XR4i Turbo Technics many moons ago which split a rad hose / overheated and blew one of the head gaskets . Seemed to be a bit of a weak point of an otherwise good turbo setup which looks like it has been remedied these days with the use of high tensile bolts .
You could up the boost a little to about 9 psi but u need to lower the compression ideally. I machined the pistons on mine rather than open the combustion chambers up like tt did. My dad runs 2 turbo technics capris and have been pretty reliable over the 10 years he's had them, only the odd problem from the injection system.
the boost is around 9psi now but possibly stretch bolts used instead on rebuild which would explain the problem. the engine is a low compression as i have checked on this. happy with the performance on this just don't want to be rebuilding constantly. reliability is now main priority. thanks for all info so far. realy appreciate it.
Sounds like u have the 230hp conversion then. Never had any problem with over heating unless poor quality head gaskets. Use victor reinz ones which are what ford used, and a decent after market fan like a kenlowe or twin fan set up off a mondeo, the front mount intercooler sits in front of the rad which makes them run a bit warmer.
thanks lee,
victor reinz head set already here. the centrifugal fan was useless and the standard pusher fan a waste of time. intercooler will need replacing and already looking looking for twin electric fan. sounds like you know your stuff on these. it's like you're describing my car. think main problem is car wasn't used for years after rebuild and gave up at weakest point when under strain. it will be sorted correctly now.
t/t
i"ve had most of the v6 t/t conversions-best i had was a 240bhp kit on 2.8i 4x4 it seemed much smoother than the kits fitted with twin airflow meters on later cars...weak point for me was rear piston on passenger side blowing rings/cracking ringlands-yes i have also had headgasket issues with them too
fastest i had was a tt280 kit[bought from mv turbos in dunfermeline-it was the owners friends car and had loads of grunt
well sorted 2.8 single turbo kit is brilliant keep fuel system clean and boost as intended-smooth and fast
they all seemed to bell out the intercoolers too-for all the boost they actually ran...
tonysierra4x4 (21-12-2014)
big_Rad
15-09-2017 09:36 AM
