Check this Engine spec out, very strange
Was talking to this lad on a clio site and he posted up this pic and spec of his RST, ive never heard of anything so crazy!. but if it works then it works, is he on here ?
ive copied and pasted it from the site
http://i196.photobucket.com/albums/a...heels001-2.jpg
Spec
block bored to 1900
mercedes cosworth 2.3l pistons with triumph V8 stag conrods and 1.8 cvh crank (lightened and balanced)
Lightened and balanced flywheel
head fully ported and polished and matched to gaskets including throttle butterfly
stage 3 hybrid turbo
Ahmed Bayjoo mapped ECU
-31 actuator running 18psi
GRS twin pass intercooler
kent fast road cam and adjustable vernier pulley
Janspeed stainless straight-through exhaust
uprated and strengthened gearbox with a shorter 1st and longer 5th
I've also removed the ABS system - it's quite heavy and not the most modern system, although I don't have ABS now the brakes seem to be a lot better than before.
I think that's everything!
Once finished it should give more power than my cup and is slightly lighter too
Spec
block bored to 1900
JoeyBoyden
04-01-2024 02:36 PM
ekjim
17-08-2015 08:57 PM
Zoggon
10-08-2015 10:39 AM
