Zetec turbo - oil return
Kapow!!
Im building a zetec turbo. What do i use for the turbo oil return, and do i weld it or thread it? Into the block or top of sump?
no silvertop has one piece sump and wants to be welded ideally as it has less chance of leaking. the tube wants to be welded above full oil level to stop it backing up in the oil line and causing the engine to smoke , if your using old sump then it should have a oil mark for the level so just drill and weld above that line.
hope that helps
cheers paul
hope that helps
cheers paul
