Zetec turbo- head modifications?
Kapow!!
Im building a 1.8 silvertop zetec turbo on a budget. Im using 1.8 20v turbo audi tt pistons, forged rods with modified small ends for pistons, rover turbo inlet, focus rs exhaust manifold and turbo.
I was going to use devil developments turbo valve springs, and a 2.0 exhaust cam and a 1.8 inlet cam. Do i need to do anything else to the head to achieve my target of 300bhp?
Port/polish, 3 angle valve seats ect? Or for the cost would it not be worth the power improvement?
Anything else i should consider engine-wise? I have all the parts, engine is coming out next weekend...
What size are the bores on a 1.8 silvertop? You might be able to use a 1800cc blacktop zetec mls gasket but you would have to find out how thick they are and calculate what compression ratio your gonna have with your piston choice.
Kapow!!
Cheers for the replies. I would be stuck without you lot.
So use a 1.8 blacktop mls gasket- on my 1.8 silvertop?
So this one would be fine?
http://pages.ebay.com/link/?nav=item.view&alt=web&id=251683256400
Really? Iv been told these Pistons and headgasket are about8.8:1 , didn't measure mine and calculate it when I built the engine to be fair 😕
I thought it was just the Gudgeon pins that are different on the audi Pistons? 19 or 20mm.. I have the 20mmm ones fitted to my engine getting me worried about the CR now.. I'm using this set up aswell forged rods audi Pistons DD valve springs and a blacktop head gasket along with many other parts
Also as there was a little confusion higher in the thread I fid need my block boring out but was minuscule probably do it with a honing tool to be honest, and to run a MLS gasket I had the block and the head decked to ensure there dead flat n true for a good seal
My mate has done it....A couple of times now. He's posted on fiesta turbo forum about it I think. Definitely have to run the thicker hg to get the cr down.
Kapow!!
Cheers!
Also, people say to use a 1.8 inlet cam and a 2.0 exhaust cam. I already have 2.0 cams, and my original 105bhp 1.8 cams. Can i use the 105 inlet cam or do i need a 1.8 130bhp inlet cam?
Kapow!!
Right, i need to order my head gasket lol- but still dont know if i should go for a 1.8 mls gasket or just the thickest one my supplier stocks?
I was going to keep my 1.8 head.
TPM961
15-01-2018 10:50 AM
