TD Mk4 Conversion
Old 20-10-2014, 08:01 PM
Kyle Langford
Kyle Langford's Avatar
Default TD Mk4 Conversion
Hi all, as some of you maybe know i have a mk4 van, wanting to do a td conversion, i have been offered a p100 td engine box and loom for 150? now my question is are the mounting points the same as its been mounted rwd?
also is it much work to get one from a mk6 escort? what would i do about wiring etc? ecu? and fuse box? cheers
Old 20-10-2014, 09:49 PM
slammedorion
slammedorion's Avatar
If your gonna go to the effort of fitting a td lump I'd look at fitting something vag tdi into it... Most Ford td lumps ain't worth the effort!!!
Old 21-10-2014, 08:19 PM
cabriolet
cabriolet's Avatar
p100 rear wheel drive? sump. flywheel .diesel pump. water pump rocker cover, various breathers,just the stuff that i can think of that is different off the top of my head you want a earlier engine last of the escorts first of the mondingos not endura . mk 4 is very tight for space
Old 21-10-2014, 08:41 PM
Kyle Langford
Cheers for the reply, I want to mount it fwd of course in on 150 a week so money is really tight with outcomes I'm left with very little, so is the p100 block no use at all?
Old 22-10-2014, 08:20 AM
Bailes1992
Bailes1992's Avatar
Get a 1.8TD out of an Escort.
It will be a few easier fit!
If you get an indirect injection engine and get a Bosch fuel pump fitted then you will be able to run it in vegetable oil!
There's no ECU as its all mechanically injected!
Old 23-10-2014, 05:05 PM
cabriolet
cabriolet's Avatar
read my bloody post
Old 23-10-2014, 07:04 PM
Kyle Langford
i read your post quite perfectly, i was just asking if it was any use at all, because im sure someone on a fb group had, wiring is where im gonna get stuck at as the fuse box is different
Old 24-10-2014, 06:59 AM
Bailes1992
Bailes1992's Avatar
Wiring is a piece of piss.
All the engine needs to run is a live on the stop solenoid.
Old 24-10-2014, 04:14 PM
cabriolet
cabriolet's Avatar
apologies for the shortness in my post in a bad place at the moment, the p100 block is useable but you need to change the sump. front cover .engine mounts the diesel pump isnt all that the flywheel is wrong .the starter is wrong, you will need to change the rocker cover and all the breathers ,alternator bracket is wrong the list is endless that is why i advised you to look for escort/ mondeo
Old 24-10-2014, 09:46 PM
Kyle Langford
Thank you for your replies, i'm sorry to hear your in a bad place mate my bad. Can i use my 1.8d wiring loom for the td then? I'm sorry its my first project and just have a lot to ask, cheers
Old 26-10-2014, 09:34 AM
marky_g
Fleet Manager
marky_g's Avatar
Get a 115psi focus complete, same engine basically just tdci, mines pretty nippy and air filter exhaust and remap will see 150 bhp and arseloads of torque
Old 26-10-2014, 07:47 PM
cabriolet
cabriolet's Avatar
no fella the [english] non endura engine has a ecu that lives in the passenger foot well and that is the engine you want. the loom unplugs on the escort at the bulkhead and the ecu you then feed it out of the car [when you are searching for a donor you want bosch; ecu ;pump and injectors] then you can up the fuelling and the boost . just a sidenote have a mk 5 cabby turbo diesel and my best mate has a mk4 turbo diesel cabby so know a little bit [apologies again for the other post]
mk3ste
17-10-2021 10:09 AM
01-11-2015 06:53 PM
Johnny Knoxville
30-09-2015 07:21 AM
SMILER258
28-09-2015 09:04 AM
mpilk
27-09-2015 09:21 AM
Quick Reply: TD Mk4 Conversion
