Veyron at Vmax
Old 23-10-2014, 07:06 PM
  #41
STAFFY OWNER
STAFFY OWNER's Avatar
Originally Posted by XRT_si
I wanted to know what he did for a living!
He wasn't an old guy, early 40s I'd say. He was taking passengers out all day and generally being very polite, down to earth and nice to everyone that asked about his cars.
He also owned the 599 parked behind the 458.
So he'd got 4 Ferraris there, lucky man. I bet his collection would make Bonkers jealous (if Bonkers still has his collection???).
STAFFY OWNER is offline
Old 24-10-2014, 12:31 PM
  #42
Fudgey
Baby Cheesus
Fudgey's Avatar
Originally Posted by STAFFY OWNER
Thanks for the reply mate, they're gorgeous cars.
They certainly are.
(i had to use google to tell you what they were tho )
Fudgey is offline
Old 24-10-2014, 12:54 PM
  #43
Luca
Lukesville
Luca's Avatar
Bit of web stalking and its this guy
Matthew Munson and an IT whizz!
Luca is offline
Old 24-10-2014, 01:08 PM
  #44
XRT_si
XRT_si's Avatar
Well done, sir!
When I got home I tried a bit of Googling and got no where!
Defo him. And he's only 34!
XRT_si is offline
Old 25-10-2014, 12:18 PM
  #45
STAFFY OWNER
He's deffo not short of a few quid, see the link below:
http://m.insidehalton.com/news-story...unson-family-/
Old 25-10-2014, 04:46 PM
  #46
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Originally Posted by turnover
Rod I have to disagree I've been bruntingthorpe many times as I live in leicestershire and the run up around the bottom bend allways helps
Disagree you may but Topspeed running is my bag . You need to gain 100m to get an extra second on the throttle at the bottom end so it makes no difference as speed gained at 200mph in 1 second is rather limited.
MikeR proved it years ago came hacking around the bottom bend best was a 180.3 run. Lined up from a standing start & set a then record of 180.9mph first time.
I agree it helps the clutch which is why we use the bend but much more efficiently than the Vmax boys do.
Rod-Tarry is offline
Old 25-10-2014, 05:05 PM
  #47
stevieturbo
C**t
stevieturbo's Avatar
That depends how hard the car is still accelerating in that 1 second. From GPS logs back in 2010 when I did mine at Woodbridge,
My car is well off the boil at that point, but even in the 1 second to 200mph, I gained 2mph.
ie 198mph to 200mph was 1 second.
Some cars still accelerating much harder would be gaining a lot more
In the 1 second prior to 190mph I gained a 3.9mph.
1 second prior to 180mph 4.6mph
Datalogs from this year at Elvington, car going much better, but still room for improvement
It was only 1km, so will only sue the 180mph time and 1 second prior it was 7.1mph gained in 1 second and covering 78m
So every little bit of extra distance and time does matter.
stevieturbo is offline
Old 25-10-2014, 09:07 PM
  #48
turnover
turnover's Avatar
Rod I'm not going to have a debate with you ,But you can't really be stood still and at that point say gain a minimum of say 50 to 60 mph from the starting point and be slower top speed
turnover is offline
Old 29-10-2014, 06:52 PM
  #49
foreigneRS
Testing the future
foreigneRS's Avatar
if you go from a standing start you can start further back than the point at which you come around the bend and join the straight - it's perfectly feasible that you can accelerate to or beyond the speed at which you come off the bend in that distance.
foreigneRS is offline
Old 29-10-2014, 07:04 PM
  #50
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
You got it that's what can happen but with so many Topspeed experts on this thread its a waste of time telling them because they know everything .
Only been my interest for 15 years what the hell do I know .
foreigneRS (30-10-2014)
Old 29-10-2014, 08:41 PM
  #51
stevecfrst1
stevecfrst1's Avatar
Are you planning to do v max when your car is back together rod?
stevecfrst1 is offline
Old 30-10-2014, 11:22 AM
  #52
foreigneRS
Testing the future
foreigneRS's Avatar
i've only been there for a single top speed event, but that was bloody obvious
Old 30-10-2014, 02:45 PM
  #53
Caddyshack
Caddyshack's Avatar
Only once pointed out.
I have been there for a drift day and it only became obvious once I was reminded that you start further back from the standing start. If not then the corner would give an advantage if it allowed you to be at a higher speed than crossing the same point at a standing start.
The corners are quite open and we were able to slide the car at over 100mph (Track prepped 911 on road tryes) but the expansion gaps tore the tyres and the paint work suffered.
Caddyshack is offline
Old 30-10-2014, 03:01 PM
  #54
RS Grant
Made in Scotland
RS Grant's Avatar
Haha, certainly not one of the best things to do en-route to speeds of 200+ is it.
Cheers,
Grant
RS Grant is offline
Old 30-10-2014, 03:54 PM
  #55
Caddyshack
Caddyshack's Avatar
Cheers,
Grant
Well to be fair we were provoking lots of sideways stuff...I certainly would not do that on the way to 200 mph and my porker was pretty much all said and done by about 150mph on the best runs
Old 30-10-2014, 05:40 PM
  #56
turnover
turnover's Avatar
Well if your such an expert Rod ,I suggest you fit a descent clutch so you can do a standing start if that's going to make you faster top end,oh wait you've got around 800 hp and nos surely the clutch can't be that bad then,strange why you'd do a rolling start then?
turnover is offline
Old 30-10-2014, 05:51 PM
  #57
Caddyshack
Caddyshack's Avatar
Isn't a rolling start just for mechanical sympathy? Why blow a record attempt on such an abrupt launch when you do not need to? Don't all of the bonneville salt flat racers get a push start to aid the long gearing and to help the clutch?
I used to love the launch starts on rally cross though...it is amazing they didn't break more often all those years ago with so much power. I think Will Gollop was around 2.5 seconds to 60 or something daft.
Old 30-10-2014, 07:47 PM
  #58
stevieturbo
C**t
I guess it depends what you're classing as a record.
Fastest speed over unlimited distance ? fixed distance ? a proper recognised benchmark, ie standing mile etc etc
But a lot of guys dont like launching their cars. It isnt just the clutch, it's the entire drivetrain.
Hence the 30-130 and even in the US a lot will do rolling 1/2 mile events now as well, or I think some of them like 60-130, which is a pretty short stat. Anything with decent power would still have no traction there anyway on an airfield lol
That said, if you're on airfield where most of this shit takes place, I can't see how you'd ever have so much traction at launch the drivetrain would be at risk in the first place.
Old 30-10-2014, 08:36 PM
  #59
Caddyshack
Caddyshack's Avatar
Aren't air field rough, high grip to help planes stop or are they poor quality?
Old 30-10-2014, 10:17 PM
  #60
foreigneRS
Testing the future
foreigneRS's Avatar
does that help when going downhill?
Old 30-10-2014, 11:40 PM
  #61
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
maybe it's got some thing too do with the fact a rwd 800+ bhp Sierra will just spin it's nuts off in 1st 2nd and 3rd
ajamesc is offline
Old 31-10-2014, 12:09 AM
  #62
turnover
turnover's Avatar
Does that mean your saying with a rolling start you will get faster top speed lol
turnover is offline
Old 31-10-2014, 12:12 AM
  #63
turnover
turnover's Avatar
Very observant,I can't help the ipad predicted spelling and didn't read it back,but you knew what it ment Mr English
turnover is offline
Old 31-10-2014, 12:30 AM
  #64
J1mbo
B1mbo
J1mbo's Avatar
Rod says his car gives full traction in 2nd gear
J1mbo is offline
Old 31-10-2014, 09:17 AM
  #65
ajamesc
ajamesc's Avatar
No not at all you were saying fit a better clutch and do a standing start. Was just saying he no doubt starts with a little mechanical sympathy so not to brake something
ajamesc is offline
Old 31-10-2014, 10:33 AM
  #66
Caddyshack
Caddyshack's Avatar
Lol, well spotted and good reply
Old 31-10-2014, 02:27 PM
  #67
stevieturbo
C**t
Airfields may be rougher than typical roads, but they have anything but good traction, well for 2wd cars anyway.
Even at 180mph at TOTB mine was still breaking traction.
Oddly, with Hoosiers at 20psi, I had to abort 2 runs around 170mph as I had no grip whatseover, could barely even touch the throttle.
888's worked better, just barely hanging on in 5th gear, but they still let go a little around 180mph.
Old 31-10-2014, 02:32 PM
  #68
Caddyshack
Caddyshack's Avatar
Blimey....that is pretty scary!
My friend took his Mac F1 to brunters and did not break 200 mph. He had the full Maclaren support package with him. He has since acheived the highest customer recorded speed though on an autobahn.
Old 31-10-2014, 04:23 PM
  #69
turnover
turnover's Avatar
Rod says a lot of things jimbo ,it's just wether you believe them or not,but I think you allready know that lol
turnover is offline
Old 31-10-2014, 05:22 PM
  #70
Jay,
Sponsor
Jay,'s Avatar
You were starting to look stupid and then confirmed it with that comment
Jay, is offline
Old 31-10-2014, 05:42 PM
  #71
turnover
turnover's Avatar
Really !!! i don't think so
turnover is offline
Old 31-10-2014, 05:50 PM
  #72
Jay,
Sponsor
Jay,'s Avatar
Come on then Mr know all fuck all what lies has Rod told ?
Jay, is offline
Old 31-10-2014, 06:18 PM
  #73
J1mbo
B1mbo
J1mbo's Avatar
Rod says what he has read, learnt or told. It's only opinions I guess and we all have different ones, I wouldn't call him a liar.
J1mbo is offline
Old 31-10-2014, 06:38 PM
  #74
Fullflush
Fullflush's Avatar
Being wrong and a liar are two different things with the same result.
Fullflush is offline
Old 31-10-2014, 08:46 PM
  #75
Caddyshack
Caddyshack's Avatar
What an odd thread.!
Old 31-10-2014, 10:56 PM
  #76
Jay,
Sponsor
Jay,'s Avatar
Yes true but the later being quite insulting
And you sound surprised it is pf
Jay, is offline
Old 31-10-2014, 11:25 PM
  #77
turnover
turnover's Avatar
Jay are you married to Rod as you seem very defensive ,Opinions we all have them ,believe what you want
turnover is offline
Old 31-10-2014, 11:32 PM
  #78
Jay,
Sponsor
Jay,'s Avatar
And that's your only come back LOL brilliant ! Come on explain why he is a liar seeing as you're so quick to call him that
Jay, is offline
Old 01-11-2014, 11:06 AM
  #79
Caddyshack
Caddyshack's Avatar
Rod has only ever seemed nice, genuine and honest when I have seen him on here, he is a nice bloke to talk to and is certainly an asset to this forum as he regularly posts....oh and he did get the record so I too find the comments a little insulting.
Old 01-11-2014, 11:28 AM
  #80
ajamesc
ajamesc's Avatar
Rod will always have haters lol and I don't think it really bothers him. One thing is for sure there hate even more come next year when his old boat sets new records and moves the goal posts yet again
ajamesc is offline
Quick Reply: Veyron at Vmax
