General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
My S1 will only start if I bump it when cold, once its started it starts fine afterwards
Can anyone shed any ideas, the fuels there its got a spark so i'm boll**** if I know whats up
Does the oil make any difference as i'ts on running in oil at the moment
Don't also discount worn starter motor or high resistance through cabling. As said, try a jump start with jump cables connected direct to starter motor (carefully) and a solid part of the block.
Does it fire at all when cranking cold? I have had this before and it was a bad earth cable but although the motor cranked it was slow and not quick enough to start
