gear selector, transit
Gents;
i dont know much about transits so i thought i'd ask you lot.
mk6 (2005) 2.4 rwd transit (with gear stick through the floor), sometimes struggles to get into gear, in particular 1st gear.
Clutch feels fine, decent biting point & not slipping etc. clutch pedal feels normal, fairly light and doesnt change through travel
now i assume these dont have cables? if not does anyone know of common issues with them trying to select gears or things i can check?
cheers
Matt
cheers
Matt
No cables the stick goes straight into top of the box,
Seen a few bend the fork on the real ease bearing, usualy makes it hard to engage all gears
When it's hard to get it inti 1st does it feel the same if you switch it off and try it?
07-10-2015 12:56 PM
The Youth.
30-09-2015 09:59 PM
