By off chance. Has any body set the timing on a relay van
The only way is dagenham
Hi all my dad has a shit'roen relay 2.2 hdi van. he was changing the cam belt when the cam moved so the timing is out and it wont start. Does any body know anything about this??? and what to do???
cheers sam
cheers sam
Remove the starter motor and there will be a hole behind it to insert a key to lock the crank.
Then a 6mm drill bit to lock the cam. There will be a hole in the Cam pully and a hole in the block.
Turn the crank slowly and hold a suitably sized drill bit in the hole and it should lock into a hole in the flywheel. Unsure what size drill bit is required for the crank!
The bottom pin has locked the flywheel.the top pin has been put in on the cam.So thay whre both where locked.The new belt was run anti clockwise from the crank and around. It was tested and spun over but would not start. The flywheel was repind and the cam was changed 180 degrees. It was tryed again it spins over but still wont start. any ideas?
I've had this on these the injection pump has a sensor in it for no.1 tdc but its marked 180 out pin the crank and cam , make sure the mark on the pump is 180 out if it lines up change it , I had this on one that the belt had snapped on common mistake apparently
The crankshaft pulley has to have the key way central in the pulley too. Had it before where van wouldnt start. There is a pin for this in the kit for this engine.
kosienutter
31
22-08-2015 09:55 AM
