price for fitting a part
Is 40 quid a fair price to fit a new egr valve... the garage im thinking of using is local to me and has good reviews online...
What cars it on, you'd be better off spending money on blanking it off...
I cant blank it off its a euro 4 electronic controlled iv tried blanking it with a plate but just brings eml on then tried it with a hole in the plate still no joy... and oh its on a fiests 1.4 tdci 08 plate
Beacuse mine is frozen/stuck got a fault code p1416 and the car is idleing rough but still runs... also I dont really fancy doing it myself cus I have a limited tool box and dont have the patience nor the time
When fitting these the EGR learned values need to be reset on diagnostics so if they're fitting it 'properly' Ł40 is a bargain!!
They're not the easiest things to get to down the back of the engine, so again Ł40 is a bargain.
Hi thanks for your reply what do u mean by values do u mean the fault code itself
After u mentioned this I checked with the mechanic to see if he would be resetting the values and he didnt have a clue what I was on about so I guess that's a no on the upside iv found another garage that just happens to have a former ford tech working there and he knew exactly what I was on about... downside Ł120 to fit oh well guess its gotta be done properly so thank you
On this car that uses the French DW4/6 engine the EGR valve is a motor with a position sensor which gives feedback to the PCM, when you get a new valve from Ford there will be a label inside that says 'Program with WDS' (WDS was the previous Ford dealer tool before IDS which we currently use)
It's not programming as such as in the PCM service functions on the diagnostics there are various options to reset learned values (EGR/turbocharger/DPF) etc and its the EGR learned values that need to be reset as if the old valve that's been 'stuck' the PCM could still think it's 'stuck' and still put a fault in on the new valve that is actually working OK.
Clearing the fault codes is not the same as this procedure...
It's the proper way to do it on these engines, they need the reset done when fitting a new valve.
Terraclean....
I know diesel engines get gummed up inside but I'm always wary of 'miracles in a can' yes they might dislodge the sludge, but where does it end up?
These engines are known for turbo failures because of oil supply problems as it is.
Also read your other thread, do they think they can fix the EGR valve being 'stuck' with Terraclean?????
Er.. these get 'stuck' because of corrosion inside the motor/position sensor not the valve part thats in the intake that gets gummed up.
Terraclean....
Thanks everyone for ur replys... after phoning round a few garages i came across one about 5 mile from me who offered to fit the valve and reset the values and terraclean the engine to remove carbon deposits all for 150 quid... RESULT
Terraclean an expensive version of chucking a can of fuel treatment in your tank. Save yourself a fortune, pay the Ł40 to get the valve fitted and codes cleared and pay Ł10 for a forte diesel treatment for the tank. I've just saved u Ł100
I been fitting egr valves to transits, mondeos, focuses and fiestas (ford hire company workshop) for years and never ever had one come back, we just fit them, erase the fault code, test drive, check for any faults and let it go out on hire. I get your a ford tech bud but we got 2 ex ford techs at my work and they both cracked up when I told them about it today and said it was a way ford coined over Ł90 plus vat off the customer to plug the computer in. That's only my experiance so please don't be offended
we only fit genuine ford parts and in none of the boxes I looked in today on the shelf does it have any paperwork inside saying about setting any values? Perhaps ford take them out before they deliver them to us? Wouldn't surprise me
Terraclean uses multiple chemicals neat through the fuel system over 2 hours to clean and decoke the engine.
It would clean an EGR if the EGR was working as it should so the exhaust gasses could flow through it. But if it's stuck shut then I can't imagine it doing anything.
It's not though is it? Terraclean uses multiple chemicals neat through the fuel system over 2 hours to clean and decoke the engine. It would clean an EGR if the EGR was working as it should so the exhaust gasses could flow through it. But if it's stuck shut then I can't imagine it doing anything.
I hear what ur sayin I really do and ur probably right but im gonna give it a whirl anyway...
Yeah might as well mate it may be good stuff I don't know I've never used it or know anyone that has I'm just well wary of the cost they charge for the treatment but let us know how u get on, might be worth it if does what they say and u get better fuel economy and power etc
Nice mAte well done ah u got nothing to lose then sorry didn't mean to sound like a cxxt in my other posts just workin in a garage u hear so much ballshit handed around, I shouldn't bring it onto a forum lol :-(
No worrys mate I drive a truck for a living delivering platforms/cherry pickers to builders e.t.c and im used to people being blunt so I know the feeling...
In fairness once you have comms with the car on IDS it doesn't take long to reset the values anyway.
What they charge out to the customer..ain't up to me.
It's only the what I call 'French' engines the 1.6 TDCI DW4/6 and the DW10 2.0 TDCI that usually have the label in the box with a new EGR advising to 'program with WDS'. (reset the learned values) the rest of the engines, yeah just fit and clear codes.
You carry on what you're doing and I will too. In fairness once you have comms with the car on IDS it doesn't take long to reset the values anyway. What they charge out to the customer..ain't up to me. It's only the what I call 'French' engines the 1.6 TDCI DW4/6 and the DW10 2.0 TDCI that usually have the label in the box with a new EGR advising to 'program with WDS'. (reset the learned values) the rest of the engines, yeah just fit and clear codes.
Just thought id give an update for anybody who is still intrested decided to get the terraclean done before buying a new valve and my god what a difference it has made the rough idle has completely gone also no more hesitation or flat spots at low speeds and mpg is up by 10 its like driving a new car much more responsive and has more power... not sure about the valve itself I will have to get it checked over but the car itself seems cured so im a happy chap for now... would defo recommend having this done if ur having the same problems I was a bit dubious at first but it really works
155lee
14-08-2015 11:21 AM
track.focus'd
12-08-2015 05:53 PM
