Mk3 Mondeo fuel pump relay location?
RWD Racer
For you Ford techies out there ....
Can someone tell us the location of the fuel pump relay in a 2005 2.0 petrol Mondeo.
Even better would be a pic of the relay so I can pinpoint it easier
cheers
cheers
Battery junction box (fuse box under bonnet)
If you look at the fuse box so the flat edge is on the left (row of fuses on the left)
The relays are on the right hand side, the fuel pump relay K4 is second one down from the top on the right hand side, its a mini relay with 4 or 5 pins.
Google images.
On this pic its the small one next to the blue connector (to the right of the connector) at the bottom.
Google images.
