Ford Fusion stuck in 4th gear and car wont start
knwlk
My ford fusion semi auto broke down and ford garage says the IDS read it as a module fault and I would need 2 x new parts - ECU and actuator! I took the parts to a ECU solution firm instead as it was cheaper. The parts were returned by this firm as fixed and tested as working. The ford garage have refitted these reconditioned parts and are now saying the fault is 'stuck in 4th gear and car wont start'! The ECU firm have agreed to look again at the parts and retest and fix, if needed. I am in a difficult position if these parts are refitted and the car still wont start/work???
Usually the actuator rod gets seized in the housing. I have done a couple of these in the last year.
IDS is required to 'learn' the transmission after any parts are replaced.
Ford dealers should know this.
Also they can get a wiring fault going to the ECU/Actuators that will put faults in, and they sometimes blow a simple fuse in the fuse box behind the glovebox that feeds an ignition live to the transmission module.
It stops it starting too....
knwlk
Another question, is it possible that the gear selectors have been messed up? i.e. the programmer is not recognising the gears cos it has been messed with since breaking down?? Hope this makes sense?
knwlk
Car still not starting. The ford garage are still saying it is faulty parts but have confirmed that diagnostics showing no faults. Ford garage wouldnt progress further and said I had to collect car so I have had to ask for second opinion. Any ideas/suggestions??? I can't beleive my car is unfixable??????
if ecu and actuators have come back ok it could still be down to programming issue.used to work at fords and programming the learning sequence can be a real pain sometimes
knwlk
ECU transmission
the reprogramming has been done and car now apparently fixed. car starts and garage said everything ok! Drove car home from garage and drove for about 10miles then engine light came on for a few minutes then light went off?? Drove car home, took it out again to see if engine light came on and it did after 5 mins of driving car??
knwlk
surely they cant charge me, the invoice said its been diagnosed and reprogrammed as OK, i daren't drive it if engine light is permanently on in case it does damage to car???
knwlk
Yes, still having problems with my car!!!!!!!!!!!
The diagnostics are now saying B2479 Brake Park Switch Circuit short to ground and P0204 injector circuit malfunction -4
Are these two codes related? i.e. if brake pedal switch not working, will it effect my injector??
knwlk
Got injector working by moving some random wires? Been running fine for over a week but now............................................my reverse gear works intermittently. If i'm on a hill/slope, the reverse will work or if i move into drive then back to neutral, then reverse, the reverse gear works?????????????????
JoeyBoyden
04-01-2024 02:36 PM
Versus_Creations
24
05-08-2015 09:32 PM
CabrioTurbo
01-08-2015 11:04 AM
