Svm850r r35 gtr v box results in finally got some race fuel out :)
#161
The logging on the Syvecs is great, but for launches etc, unless you've an undriven wheel vehicle speed reference on a 4wd car it's difficult to use any data when wheelspin occurs. Really the only way to get that with 4wd is via GPS input or similar.
Once moving and all wheels have traction, it isnt a problem though so would mostly affect trying to work with 60fts and short standing start data
But for mine with a front undriven wheel, it's fine. It shows a distance field in the logs which is handy for pulling your own stats from runs whether road, track, strip etc
Even down to 60fts
Even down to 60fts
#162
Even down to 60fts
Even down to 60fts
ryan did show me a 0 - 100 in 4.9 seconds run but I guess some wheelspin could of influenced that run then being syvecs based, I shall continue to use the vbox as it makes all my data comparable, syvecs will be more of a learning curve for me as its the first ecu ive ever had I can communicate with
#163
For the most part using the logging is safe....it's separate software from SCal so you cant actually do any harm pulling logs or setting what parameters to log
Although the parameters to actually activate the logging are within SCal...where you could hit wrong buttons.
So first thing when you connect to the ecu for the first time, save the current calibration and make copies of it somewhere safe before tampering.
And when changes are made, give them a new file name, or add 01, 02, 03 etc to the end so you can easily see previous files.
#164
I will have to tread very carefully as its all unlocked lol
ryan spent many many hours mapping it I wouldn't fancy having to pay for all that again due to me being a 5 year old with a new laptop clicking everything lmao
#165
well ive finally put some ethanol in it and done some pulls
I used no launch at all just clicked in drive and nailed it for both of these pulls
v power 1.6 bar boost 0 - 130 mph 9.3 seconds
and 45% ethanol 55% v power 1.8 bar boost 0 - 130 mph 8.6 seconds
30 - 130 mph now down to 6.24 seconds aswell im well chuffed with that
60 - 130 mph on the ethanol map I got 5.02 seconds, so close to a 4 I reckon she would make it just into the 4s when its dry warm tarmac
traction felt a lot better on the v power run but that was back in much better weather than we have now.
#166
Sponsor
Fuck me and there was me thinking I could get close to a 11sec 0-130 with less than 600 bhp cant see that then
#168
your a lot lighter than me though mate I need 950 hp for the fat arse gtr lol
I reckon with a full bore launch 0.7 seconds will come of those times aswell, from standing start my 0 - 60 should be 2.8 seconds
#169
we went to bodiam castle on Thursday 4 up everyone was happy 240 mile round trip and only used 2/3 of a tank of fuel aswell just cruising at 60 - 70 mph
#171
I think your in the right ballpark mate I did 0 - 100 mph in 7.2 seconds with the r33 at 710 hp stock weight 1540 kg so 461 hp per ton
seems to be 1305 kg 4x4 saph, so 600 hp saph would be 459 hp per ton so almost identical to my r33.
I did 0 - 130 in my r33 in 11.3 seconds so im sure you will be around that mate or quicker with 600 hp, my launch and shifts wernt perfect for that 11.3 either
#175
I hope so bud, if I can do 0 - 130 mph in 8.6 seconds with no launch in cold weather, I reckon a 7 should be doable shouldn't it in perfect conditions, perfect run ? im thinking a launch should gain me 0.6 - 0.7 seconds alone, plus with added traction through the lower gears should gain some there aswell I think.
#177
well my youngest has got me up wanting some munch
so ive loaded some more data
just looking at my qtr mile run
it recorded 10.91 at 117 mph but I backed off the throttle at 9.3 seconds into the run
as you can see I hit 137 mph then backed off and coasted over the line at 117 mph
from studying the plot I think it would hit about 150 mph staying planted across the line.
and my 60ft plot from that run at 2.7 seconds lol
I should be able to do a 1.6 60ft on the r888s with launch control so theoretically it should do about a 9.6 at 150 mph roughly on a good run race fuel.
to do a 10 though with a 2.7 60ft and backing off is a good start if nothing else lol
and a comparison red run is v power map, blue run racefuel map
I crossed the line at 144 mph in v power run, the race fuel map is 7 mph ahead when I back off so in theory should of been 151 mph.
#179
id better get my (forget about the gearbox) shoes on then lol
I found those 30 - 130 plots from my other thread robw added I know there old ones but even so shows my 6.24 seconds is well up there especially considering my car is just stock gearbox and diff ratios aswell and has a massive top speed still
there may be a little more in with hot tyres and tarmac but I cant see it breaking out of the 6s 30 - 130
#181
I will get some vids at some point mate I always forget I struggle enough to remember to put it in race mode, I think to much work is driving me abit scenile already the vid in this thread is a low rev limit and 1 bar of boost, it sounds a lot more menacing with 1.7 bar of boost and 7450 rpm
it does definitely feel quicker from the seat.
the comparison I did earlier of 0-130 is abit off as the vpower run lost a 10th due to traction control kicking in hard.
so to ignore that tenth lost ive done a 60 - 130 mph overlay
v power blue vs e50 red
it is crazy how much more power is needed for just small increases in speed
from my dyno plots the race fuel map vs the v power map has an additional 116 hp, but in real world terms all it did was accelerate me from 60 - 130 in 5.02 seconds vs 5.49 seconds, so 0.47 seconds quicker which doesn't seem much really for an additional 116 hp lol
it does feel considerably faster though I must say
#182
Mega impressive times! Who runs that 30-130 shootout then? Looks like an interesting event.
#183
1/2 second over such a small speed is a pretty big increase in performance.
10% reduction in time for what % increase in power ?
MLR run the 30-130 event most commonly run in the UK, although I think the times posted above are 2-3 years old ?
Cant seem to find most recent ones
gjh (02-11-2014)
#184
Good point I hadn't thought of it like that by percentages
So I have done 60-130 8% quicker with 13% more power, I guess that's actually really good going as double the power doesn't double the pace
Those 30-130 results are a few years old, they are probably in the 4s now I'm sure the svm hulk is and that mental Scooby :-o
#185
From Andy's recent 7.87 at Santa Pod, which is obviously different to an airfield etc.. ( Although he did a 7.7 last weekend was it ?
On the 7.87 run he recorded a
3.54s 30-130mph
2.7s 60-130mph
0-180mph in 8s lol
Obviously you can't even begin to compare the two cars though, they're a million miles apart in every respect other than approx engine size, cylinders and number of turbos.
3.54s 30-130mph
2.7s 60-130mph
0-180mph in 8s lol
#186
3.54s 30-130mph
2.7s 60-130mph
0-180mph in 8s lol
3.54s 30-130mph
2.7s 60-130mph
0-180mph in 8s lol
Whole other planet quick that thing, but as you say not really comparable as it's a stripped out half the weight race car. Mighty impressive though it must be an immense feeling driving it
It's crazy to think that Scooby does 60-130 nearly twice as quick as my gtr is it 1000bhp and 1 ton ish?
For the first time in many years I can honestly say 100% I don't need more power in my street car, YET lol
#187
you can never have enough power lol!
#191
I realised a couple of things last night looking at the figures.
im now dead heat with a 1200hp Veyron supersport 60 - 130 in 5 seconds, I know it would kill me top speed but im still chuffed I could live with it in real world situations
and my 1/8 mile trap speed of 120mph is almost equal to the 1/4 mile trap speed of 122 mph of my old 580 hp r32 gtr lol
next up is a launch test and see if I can 0-100 mph in the high 4s......
ive done 5.8 so far with no launch
#193
#195
cheers mate it is far beyond anything else ive ever had
I havnt done a thing to it mate, ive done 800 miles in it and put half a litre of oil in it, it needed the hose reseating for the flex fuel sensor which is done, I just need to fit a new windscreen wash pump I got it just not had time to fit it yet.
I only tried the full power map last weekend hence only just getting in the full power figures.
my mate went in it and said "its not as quick as the supra" to which I said no its MUCH quicker lol
its so poised and planted where the supra was just a monster that felt quicker even though it was a lot slower lol
#196
Ben
That's redonkulously quick!
Out of curiosity, how much is the race fuel you've been using?
#197
I don't know mate it came with the car.
I think it is e100 ethanol, I put 20 litres in and after 5 mins of driving the ethanol content on my gauge was constant at 45% so near enough full power tune at max mapped boost
its mapped to run at 50% ethanol for 960 hp 1.7 bar
CrOwSoN15 (07-11-2014)
#198
well the car has had its first repair done.
ive had it 6 months now done 1000 miles in it and weve just done the windscreen washer motor, old unit seized.
touch wood that's it, so far, in the r33 and the supra both running big power everytime I used them something broke, literally !
I have no illusions of immortality lmao, but so far its been super reliable, I cant fault it
#199
I have been pondering on a private plate for the gtr, nothing silly money just something personal to me or the car.
So far I have found V38 GTR the engine is a vr38 so the plate sits well but it's £1000!
Why is that £1000 is it because it's 6 digit plate? Seems overpriced to me
#200
ELASTIC BAND
because of the reason you want it. 38 and gtr being part of the plate.
