Msd wasted spark
Msd wasted spark
Hi. I've got the wasted spark conversion from msd. I got them to fit the driver to my super 8 ecu running 8 injectors but i haven't had the car running properly since. I sent it back to them to get checked and when i got it back it only ran on cylinders 2 and 4 a few times but won't start at all now. I've fitted a new amp as i thought it could be that but made no difference. I took the spark plugs out and they all spark initially when i turn the ignition on but when i turn the engine over only cylinders 2 and 4 spark. Any help would be appreciated as i'm tearing my hair out lol
Thanks
Thanks
have you got the plug leads correctly on the coil pack? reason I ask is because the wasted spark fires 1&4 and 2&3 together, so either your coil pack is fooked or you have the ht leads on the coil wrong and one half of the coil is not firing?
It had a slight misfire before that got worse that's why I got the wasted spark but it turned out to be the cylinder head was cracked. Just had the engine fully rebuilt and bench dyno'd so I know it's something electrical. It was run in on distributor and diff ecu tho.
I did think it's maybe my luck that a new coil pack is faulty but then I'm thinking it still could be the ecu not telling it to fire?
Swapped the wires over and cylinders 1 & 4 are firing now so coil pack is working. ECU fault it seems to be then. Back to Motorsport developments for the 3rd time. Had the ECU checked on another car running msd wasted spark and it's popping and cutting out and won't start again the same symptoms i'm getting.
That's not confidence inspiring lol. Yeah I've had the issue for months also
I keep reading about W/S ECU's tested???? I may be wrong but since when did MSD start servicing and testing ECU's - i was under the impression that James tests the ECU on a like for like car not the actual ECU as i had mine checked in the early days, i had the driver fitted in 2009 and had to wait for a L8 W/S car just to plug in and see if it would operate but mine turned out to be the baby board ribbon had failed.
So if James has said it operated fine then you need to start looking elsewhere on the car
The driver board was fitted by MSD. I wouldn't attempt opening the ECU up myself. Yeah the ECU seems to have an issue but it was functioning fine before I decided to go for the wasted spark. That's what's frustrating.
Well if thats true im quite disgusted , I wouldnt be happy if my car was at MSD and they were plugging in other ECUs into my car that could have faults
Not exactly what you would expect , your car being used as a test bed for faulty parts
Shocking ,
Why do most people defend MSD on here? Have these people defending them ever used them?
My personal experience of MSD was not good. I won't go into specifics but suffice to say I spent a tidy sum with them and was not happy at the results. Before anyone asks no I didn't contact them about the problems because they would not give any kind of warranty as it was a rally car.
