Saph front arb and adjustable tca problem - Updated
So whats wrong here then?
have I got a 4x4 arb? I can't see any markings on it.
It seems to have loads of caster. Its a bit odd as I used to run the same arb on my old car with spacers behind the tca to increase the castor.
The only difference is the tcas on the old car were standard and used floflex bushes where this is using powerflex black series, also the crossmember which is a base model one, I couldnt see any difference between the cos and base model cross members but I did have to drill the holes out to 12mm to get the bolts in for the inner rose joint
I had to use a ratchet strap to pull the rose joint end back to get it together as the bushes are so stiff, when I tried one of the old ones with the floflex bushes I could put it together easily by hand and it looked ok but the bushes were quite twisted..
Resident Wrestling Legend
i would agree that the arb would seem to be the 4wd one
without putting them on top of one another though it's very difficult to spot the difference by eye alone, the 4wd ones from memory pokes out at a different angle and it slightly wider than the 2wd one, but it may be the other way around
Bummer... Always something...
i put a 2wd bar onto my 4wd sierra and the handling was amazing, but the straight line normal driving was always on the edge, almost like it was fitted with an f1 steering rack
i ditched it after about 3 weeks of proper nervousness, but going round corners it was stuck to the road like shit to a blanket
I have Always wondered whether the 2wd sapph cossie arb is the same as a 28mm arb from a standard sapph. At least they are both 28 mm thick. I have a standard 28 mm arb on my sapph and I have no issues with the wheels being too far forward. In fact I added washers to push the wheels more forward to increase caster.
A Granada Cosworth arb will give the same caster setting as the 28 mm standard sapph arb does. The only difference for the Granada Cosworth arb is that it is a little wider due to the longer tcas on the Granada and that it's 29 mm thick instead of 28 mm.
I will see how it looks when the 2wd one arrives.
Are the cross members definalty the same? They didnt use a slightly different cross member with the tca mount moved slightly forward on the cosworth?
If it still isnt right I might ask Ridgey if I can take some measurements off his car to compare.
So i received my 2wd Saph ARB today,
Offered up against the original... not much difference? not as much as i was expecting anyway
it is a little bit shorter, but not much difference in the angle.
So i thought i would see how it looked on the car
a bit better...
Popped the hub and shock on, and a brake disc and old wheel to see how it sat in the arch
its still forward in the arch but not excessive.
from what i have read, the H12 original 3dr arb, was replaced with the h14 which gave a little extra castor to improve stability. Does anyone know where these marking are as i can't see any on either of mine?
I'm wondering if i have gone from a H14 to a h12, and i have another problem somewhere?
Not that it matters too much anyway, i will measure the castor as soon as it is down on all 4 wheels and see if it is within spec for a standard saph cosworth.
a bit better...
so it's virtually what i said then
when you get it onto the ground the lower it will be the further forward into the arch the wheels will go because the length of the physics is fixed so you will arc forward the lower it goes
comp struts will allow you to move the wheel backwards and a front mounts arb will leave you with the ability to run softer springs
but it is lots of overkill if you are going racing
jessie_rs
11
03-06-2019 04:57 PM
155lee
14-08-2015 11:21 AM
