97 Escort van brakes binding
Just got back from work and noticed my brake must have been binding on the nsf.
The wheel feels really really hot, it feels like it wont roll when in traffic and the performance is dire.
Is there a quick fix to free it off, or is it worth getting hold of some GTi (or similar) hubs with brakes, shocks etc?
Not really handy with the spanners myself so a bit in the dark as to what fits what lol
It could well be mate, I just thought i'd ask to see if there was a common thing at fault with these vans before I have a look underneath tomorrow...
Thanks you two, I shall do some investigation tomorrow and see whats happening.
Want to get it lowered on its arse and some steels banded but need to get it the little niggles out the way first lol
Make sure the clamp holding the rubber hose to the wing isnt pinching the hose.
Had this on mine i stripped the caliper etc and noticed clip was too tight, fluid could go down but not up holding the caliper on
It seems to be fixed. Wheel off, undo brake hose from caliper,turn wheel, free off hose bracket, bang the caliper a few times with a trusty hammer, then refit wheel.
Jobs a gooden!
Probably replace the brakes and suspension eventually anyways but happy days.
Jobs a gooden!
Ford escort van brakes jamming binding on intermittently
MY VAN IS THE SAME
Hi, I have an escort van 1996 and the brakes are jamming on intermittently, i need help.
Ive replaced both front callipers,fitted new pads,lubed up the sliders etc, also fitted new rear drums and shoes and it still jams on intermittently. New servo i am sure was fitted before i bought it,i need help could it be the flexi pipes?.
This is whats happening front right brake jams on and so does rear left,whcih is weird at the same time, sometimes will free off whilst driving,other times pumoing the brake pedal with quick jabs also does it.
What definetely frees it off,is if i take a n 11mm socket to the front right bleed nipple and slacken it a alittle then retighten, this always releases it.
Any help anyone, this is driving me crazy,hot smoking wheels when pulled up.
Could the load sensor valv thing underneath the van cause these symptoms,mine just looks like a piec of metal rattling about inside a coiled loose spring.
