transit connect immobiliser.
Old 28-04-2012, 07:12 PM
michael harbour
michael harbour's Avatar
Default transit connect immobiliser.
help.... my mate 05 connect as immobilised its self
any ideas ??????????
Old 28-04-2012, 07:19 PM
GVK.
GVK.'s Avatar
Does it crank?
Is there ------ on the dash instead of the mileage?
Didier Bidaux Olivera (10-03-2021)
Old 28-04-2012, 07:27 PM
michael harbour
Originally Posted by GVK.
Does it crank?
no mate just the little red light flashing fast when you put ignition on?
Old 28-04-2012, 07:33 PM
GVK.
GVK.'s Avatar
That normally means the key isn't recognised.
Does he have a spare key to try, or has that already been done?
I had one (diesel) recently that wouldn't start/crank and it was the small black power hold relay (powers up ECU) failed in the underbonnet fusebox. I swapped relay for the one next to it that's marked fuel pump, to try it.
http://ww2.justanswer.com/uploads/s4..._Focus_BJB.jpg
C1403 in this diagram.
Check all the fuses in both fuse boxes too.
Old 28-04-2012, 07:54 PM
michael harbour
spot on mate thats it running. cheers
Old 28-04-2012, 07:58 PM
GVK.
GVK.'s Avatar
Relay?
Old 28-04-2012, 08:14 PM
michael harbour
Relay?
yip cheers
Old 28-04-2012, 08:22 PM
GVK.
GVK.'s Avatar
Sweet! Good guess
Old 05-12-2012, 05:50 PM
milimwshajonti
milimwshajonti's Avatar
hi, i have an 06 transit connect tdci, i have a problem with it in the mornings, does not crank and milage does not display it only shows ------ when this problem occurs. seems only to happen on colder or icy mornings. it will start in the end after few attempts but problem seems to be getting worse!!!
Old 07-10-2014, 05:44 AM
ian50
ian50's Avatar
Default connect
Does it crank?
hi i see you have posted a question about the - -- - - in stead of the mileage i have the same problem and mine does not crank help
Old 07-10-2014, 05:53 PM
milimwshajonti
I had the same problem on the colder mornings, mine is a 56 plate, i understand that the have different fuseboxes on different ages.in the fuse box under the bonnet there is a row of four small black relays,2 for lights 1 for fuel pump and 1 is the power up relay(r8),this was the one that caused the problem for me. Swap it with one of the light ones to try it.this is what i did and its gone ever since!!
Old 07-10-2014, 05:54 PM
milimwshajonti
Let me know how you got on!!
Old 06-12-2014, 01:52 PM
jamieq22
jamieq22's Avatar
Talking -----
I have a 2006 ford transit connect, had the ------ instead of the mileage, the van would not start or even make a sound. I knew it wasn't the battery because all the lights worked and I tried to jump start the van which did not work. After reading on here it could be the relay I changed relay (8) which looks like it has a pump picture on it with one of the lighting ones as suggested by milimwshajonti. It started first time so happy I punched the air, know i don't have to spend stupid money on stupid mechanics. After driving around a few shops I found found a relay for just over Ł5 at whoopee motor factors. (Cheaper than i thought) the only problem know is the code needs to be re entered into the radio and I seem to have lost it.....
Old 24-09-2015, 10:08 PM
Lukebradbury87
Lukebradbury87's Avatar
Default After reading this
After reading this about the immobiliser and not cranking I was jumping for joy and jumped into my car for a trip on what I fort may fix my van 🙈 on arrival van was doing same thing red light blinking not cranking. I done what I read and removed the relay and swapped for another, nothing! Red light stopped blinking but still no crank HELP!!
Old 06-01-2017, 08:22 PM
Enda De Bruin
Enda De Bruin's Avatar
Default Ford Connect wont start after head gasket
Hi
I changed the head gasket and the timing belt and timed the crank and cam up but did not remove the fuel pump. I primed the pump and have fuel coming to the injectors. No issues that i can tell with the immobiliser but it will crank and will not fire even on a tow. Any ideas ?
Old 10-03-2019, 10:36 PM
GC47G
GC47G's Avatar
2008 transit connect , with siemens fuel pump . Won’t crank or turn over , can someone point me in the direction off where to start .
Old 11-03-2019, 04:46 PM
You getting power to the starter motor when trying to crank??
Old 10-03-2021, 08:38 AM
Didier Bidaux Olivera's Avatar
Hello to everyone in the forum! Had the same problem that @MichaelHarbour, and I didn't found why (I`ve checked cluster, wiring and ECU). So, the reply of @GVK. was absolutely effective!
The R8 relay was the problem! I've changed to try, but worked perfectly. I've bought a new relay and finish the job!
Old 10-03-2021, 06:44 PM
GVK.
GVK.'s Avatar
Thanks for posting
Old 13-11-2022, 04:50 PM
beretta687@googlemail.com
beretta687@googlemail.com's Avatar
Default 2003 connect van
Having a night mare with 2003 van after 10 starts it doesn't start. The immobiliser light just flashes constantly, then I have to take it to local mechanic to reset the system
Ive bought an additional key and the same keeps happening. The other day we replaced the body control module Ł400 still not working won’t start again after 10 starts.
please help is there anything I can try ?
Old 13-11-2022, 04:56 PM
GVK.
GVK.'s Avatar
Need to know error codes when its faulting really
Old 13-11-2022, 04:58 PM
Is this counting how many times the red light flashes ?
Old 13-11-2022, 05:06 PM
GVK.
GVK.'s Avatar
No, needs the van scanning for codes in engine ECU, and instrument cluster if applicable.
When your mechanic reset the system there should have been codes set.
Old 13-11-2022, 05:09 PM
GVK.
GVK.'s Avatar
If there is a flash code on the red immo light I can't remember what the codes mean these days. A google may help.
edit - https://www.fordwiki.co.uk/index.php...er_Fault_Codes
https://mhhauto.com/Thread-PATS-SECURITY-FLASH-CODES
Old 14-11-2022, 05:30 PM
Thanks tried taking a look but just can’t figure it out, van is so clean so reluctant to scrap but spent more money on it then I’ve bought it for so scrap yard I think it might be lol
ian50
23-10-2014 06:20 PM
mrtetley
06-02-2010 10:07 PM
tosh
15-11-2009 04:26 PM
dojj
02-09-2008 08:36 AM
Quick Reply: transit connect immobiliser.
