Aircon issue, windows fogging up?
#41
I appreciate your replys.
I will check it over weekend but I really feel that this issue it not a coolant leak or water coming in the car. The windows arnt steaming up. It's a film, hard to explain sorry. Also, the car smells good which is why I really dont think Ive Got water coming in. It's always done this since owned this car since December 2011, The above comment off ffoc would make more sence?
Keep the ideas coming though.
#42
big floppy donkey dick
have you cleaned the under carpet since the clutch fluid problem?
take the carpet out completley and try that,
i agree with lack of air movment in the cabin, rubber flaps behind bumper not gummed up with mossy crap are they?
#43
Will get a chance to check it over weekend, it's not been a big issue over winter, just on warmer/ dryer days I'm cleaning all windows every 24 hours.
I like keeping my cars mint but cleaning every window on the focus everyday is doing my head in.
It's just mine and the misses daily, don't wanna be as anal with the cleaning on this.
#45
Testing the future
a greasy film is clearly not normal water vapour, so something else must be in the cabin either in the flooring or coming directly out of the hvac (could either be antifreeze fro mthe heater matrix or oil out of the a/c evaporator)
#46
Not using a drop if water so matrix must be fine.
Ac has just been serviced and given the thumbs up.
#48
The system has been tested for leaks. It's all been cleaned and renewed.
#49
Testing the future
how exactly was it tested it for leaks? what were the results of the leak test?
i'm not sure what exactly would have been cleaned and renewed??
have you just had a monkey put an automatic machine on it?
#50
you would only need a very small amount of coolant or refridgerant to cause a film on the glass, did the A/c have a full nitrogen test as well? what was the recovered weight and when was it last done (previous to this time) and what where the result of that ?
you have to think logically with something like this, something has to be inside the car allowing the contamination of the glass surface.
chowfornow
14
05-01-2019 09:01 PM
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
