Hart / AS inlet support
#41
#42
Check this thread for info - https://passionford.com/forum/ford-s...n-finally.html
#44
Originally Posted by 4x4pete
Who done them for you? Do you know the thread size ?
#48
Happily retired
#51
What i need to know is with the standard set up being attached to the TB and built up with a number of washers etc - is this set up meant to have give in it or is it fine being bolted solid at the inlet end or should some sort of rubber seal be used?
#55
cossie fan (unluckerly)
I cut the original mount in half and welded a bit in the middle and it's just bolted to the manifold same as its always been for the 11 years I've had the car
#60
The washers are not flat, they are dished and when fitted in the correct order provide the dampening. They look like this
There is no movement but you can imagine if you have two facing each other they will be springy even though they are not lose.
There is 6 IIRC and they go in a certain order. I think its three pair with the cones facing each other. Wish I never sold my workshop manual now!
#63
if your that worried about it just go bolt metal washer then fiber washer then on the other side fiber washer metal washer and a lock nut then nip it up this will let it move about a small amount
#64
Would something like this be a good idea I know the Jap boys use them.
http://www.ebay.co.uk/itm/Torque-Dam...item2573b1f077
Rich
Rich
#66
Did you eventually sort this out Brammer??
I've just had to weld my head back up as the bottom bolts on all 4 ports had snapped off mine as per the pics on page 1. No big issue for me as my engine is out for a freshen up anyway and I have my own fab shop, but I do want to prevent it from happening when the motor is back in!!
#67
Yes pal the washers are available from Burton Power
http://www.burtonpower.com/cosworth-...kit-sc565.html
in this order (()))) as above
And the bracket - but for the aftermarket inlet you have to cut and add about 10mm
http://www.ebay.co.uk/itm/Ford-Sierr...-/390527380202
#68
07-10-2015 12:56 PM
Johnny Knoxville
30-09-2015 07:21 AM
DavidK
27-09-2015 02:55 PM
