Is it normal for air to blow out of oil cap? - PassionFord
Old 09-03-2011, 07:47 AM   #1
BM08
Default Is it normal for air to blow out of oil cap?
As title just discovered mine does when the engine is running, just wondered is it normal?
BM08 is offline   Reply With Quote
Old 09-03-2011, 08:04 AM   #2
rubinsbin
do you think its normal?
isnt it followed by oil being blown all over the engine when the bonnets down!
rubinsbin is offline   Reply With Quote
Old 09-03-2011, 08:11 AM   #3
Would you say there is a lot of pressure there with the cap off.
Glenn_ is offline   Reply With Quote
Old 09-03-2011, 08:11 AM   #4
tommytwotanks
tommytwotanks's Avatar
im no expert, but i'd say it''s not normal, probably worn valve stems, do you get any smoke coming up ?, my brother had this many years a go on a fiesta mk1 1100
tommy
tommytwotanks is offline   Reply With Quote
Old 09-03-2011, 08:29 AM   #5
vwturbo
if the engine noise increases when u remove the oil cap, and it makes this chugging sound.. somethings up, bottom end pressure or something, one of my cars used to do it, then it threw a rod 2 weeks later.
vwturbo is offline   Reply With Quote
Old 09-03-2011, 08:47 AM   #6
Dicko&Vacant
Its normal when the engines fooked lol
Dicko&Vacant is offline   Reply With Quote
Old 09-03-2011, 09:05 AM   #7
MAD Ade
MAD Ade's Avatar
A generally worn engine most likely.
MAD Ade is offline   Reply With Quote
Old 09-03-2011, 09:11 AM   #8
It depends on your definition of air, a faint breeze is normal, anything more points to pressure in the crankcase, no engine in the world will seal 100% so there always will be some, but a faint breeze.
tabetha is offline   Reply With Quote
Old 09-03-2011, 09:53 AM   #9
SiZT
Nothing to worry about, it's just VTec kicking in
SiZT is offline   Reply With Quote
Old 09-03-2011, 10:13 AM   #10
BM08
It's proper blowing but no smoke at all, car seems to run fine and go well....
I've checked google, some say it's bad others say it's normal.....
Old 09-03-2011, 10:17 AM   #11
Eagle
Super Moderator
On my escort it was due to a nice hole in a piston...... Man that made me laugh ......... Put the cap back on and turned it over it blew the cap god knows where lol
Eagle is offline   Reply With Quote
Old 09-03-2011, 02:43 PM   #12
BM08
Anyone else? Whats the best way to test if it's ok or terminal?
Old 09-03-2011, 02:51 PM   #13
ECU Monitor Enthusiast
Firstly, check the crank case breather is connected and also not blocked up !!
Disconnecting the breather will increase the air flow out the cap as a check
If all else fails, get a compression test done for all cylinders to check you havent got excessive bore wear or holed piston !
ECU Monitor Enthusiast is offline   Reply With Quote
Old 09-03-2011, 02:53 PM   #14
Fast Guy
As said above it's normal on a worn engine. On a good engine there should be a slight vacuum.
It tends to be blowby from the piston rings pressurising the crank case.
Compression/leak test your engine. You could run like it for years if its only worn rings, but fix it if you can afford to.
When it gets really bad it can start blowing oil through the breather system into the intake and give clouds of smoke out the exhaust. This will most likely happen after you top the oil level up or slightly overfill it.
Fast Guy is offline   Reply With Quote
Old 09-03-2011, 05:45 PM   #15
BM08
Thanks for the replys chaps
Just popped it round to Honda earlier and a techie came out and had a look, he unscrewed the cap abit and said thats fine mate.
Extremely mint rwd focus cosworth shell Focosmitch Ford Focus RS Parts for Sale. 5 09-03-2016 02:03 PM
Extremely mint rwd focus cosworth shell. Focosmitch Cars for Sale 8 05-11-2015 09:12 PM
Extremely mint rwd focus cosworth shell Focosmitch Ford RS Cosworth Parts for Sale 5 03-11-2015 05:08 PM
Cosworth bits and bobs Focosmitch Ford RS Cosworth Parts for Sale 15 07-10-2015 04:43 PM
Tools Explained hopper350 Garage / Workshop & Tools Section. 2 04-09-2015 01:53 AM
Tags
2000, 300, air, blow, blowing, cap, car, focus, ford, honda, inline, noise, normal, oil, smoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
