PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 20-06-2010, 05:14 PM   #1
smartrs
smartrs's Avatar
Trader Score: (0)
smartrs is an unknown quantity at this point
Send a message via MSN to smartrs
Default saff cosworth fan relay
my fans are not cutting in on my saff and i think i narrowed it down to the relay (i think) where can i get a new fan relay from ? or any other ideas on wat it can be ?
__________________
smartrs is offline   Reply With Quote
Old 20-06-2010, 09:22 PM   #2
Trader Score: (0)
tabetha will become famous soon enough
Are you on the oe set up, ie through the fusebox ?, if so ditch it before a fire starts, and make a seperate loom.
The relays are std fit SPST relays, someone like www.vehiclewiringproducts.co.uk do these as well as most car shops.
Just be aware that there are two types of pin layout, known as type S and type B, so check this.
tabetha is offline   Reply With Quote
Old 20-06-2010, 09:28 PM   #3
smartrs
smartrs's Avatar
Trader Score: (0)
has any one got a digram for the bypass loom ? as it is probably a good idea to replace this need to do the fuel pump too were do people fuse these bypass looms to keep things looking neat ?
__________________
Old 20-06-2010, 10:42 PM   #4
RS_Andy
Trader Score: (0)
RS_Andy is an unknown quantity at this point
Hello Smartrs, have a look at this post I had the same problem, all sorted now by making my own loom
http://passionford.com/forum/technic...ml#post4961677
__________________
RS_Andy is offline   Reply With Quote
Old 20-06-2010, 10:43 PM   #5
Tev
Tev's Avatar
Trader Score: (2)
Tev is an unknown quantity at this point
Quote:
have you by anyhance swapped over to a lly rad?
__________________
Tev is offline   Reply With Quote
Old 20-06-2010, 10:55 PM   #6
smartrs
smartrs's Avatar
Trader Score: (0)
no still standard rad but the engine has just been rebuilt so the rads been off the car
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
