PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 26-05-2010, 12:34 PM   #1
smudger068
Trader Score: (0)
smudger068 is on a distinguished road
Default fiesta 1.8td mk5...more power
hi,
i know im not expecting much power increase but as i need something that is economical to run me to london n ipswich and back everyday, and with 1500 pound budget i went for this so, im thinking of a scrap yard intercooler, zetec s cat back and air filter, just for the fun of doing it really, and keeping it cheap and cheerful
but im stuck...when upping the fuel will the boost naturally up itself or how do i actually up the boost on the turbo
thanks
smudger068 is offline   Reply With Quote
Old 26-05-2010, 04:04 PM   #2
percybigun
Twistin me melon man
percybigun's Avatar
Trader Score: (0)
percybigun is an unknown quantity at this point
Send a message via MSN to percybigun
front intercooler, bleed valve for the boost (run it in line with the pipe on the actuator) for which you will also need to rig up a guage, and you have to up the fuelling on the fuel pump screws mechanically.
dont just up the boost or it will run uber-lean.
i used to run a mondeo 1.8TD with saab front intercooler, 20psi boost, fuelling wound up as far as it would go, large induction kit (the standard airboxes really restrict them, as do the gay K&N 57i cone filters) with a powerflow cat-back exhaust - it was pretty nippy and not that smokey!
if i got another one i would do all that, then get the flywheel heavily skimmed, decat and fit a bigger turbo with an adaptor plate.
check the thin black rubber pipework around the turbo (especially the long one that runs to the fuel pump) if it is all perished you will be losing a bit of power. on the mondeo there was a small shock absorber on the throttle mechanism (on the fuel pump) which gives it throttle hang. remove it and bin it if yours has one!
percybigun is offline   Reply With Quote
Old 26-05-2010, 04:13 PM   #3
R4N S S
R4N S S's Avatar
Trader Score: (6)
R4N S S is on a distinguished road
if you need any parts let me know as my mate has my old one sitting on his drive after he blew the turbo.
I put a brand new diesel pump on it before i sold it too
__________________
RAN
Middlesex RSOC Treasurer
Moonstone 3dr gone
White 3dr Track car being built and restored
http://passionford.com/forum/restora...abuse-car.html
E36 325i Drifter
R4N S S is online now   Reply With Quote
Old 26-05-2010, 10:00 PM   #4
smudger068
Trader Score: (0)
excellent thanks guys,
found this link http://www.boostvalve.com/ thats explains about inline valves but how do i fit a boost gauge? can i run a 'T' piece for the guage then run a bleed valve off the other side??
and what is safe boost pressure with keeping it economical obv im goin to lose some but just dont want to go OTT
thanks again guys
Old 27-05-2010, 09:08 AM   #5
percybigun
percybigun's Avatar
Trader Score: (0)
on mine i put a t-piece on the pipe going on the actuator for the bleed valve, and another t-piece on the thin boost pipe between the fuel pump and turbo for the boost guage.
i'm not 100% sure yours is the same as the mondeo 1.8TD endura-DE engine, maybe the fiesta has the direct injection engine and an ECU? if so you would need a tuning box for the fuelling.
Old 27-05-2010, 01:32 PM   #6
smudger068
Trader Score: (0)
my one is the one use in escort vans, i adjust pre-boost fuelling and in boost fuelling by the adjusting screws by the throttle where the damper is i believe i have to turn up the fuel pump aswell...just was unsure of the boost...did find a forum which was the mondeo oone were it explains how to up the fuel
thanks for your help
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
