| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
#2 |
SHITE!
i THINK they are mechanical mate, been a long time since i looked at a Ka engine lol.
#3 |
If you need to adjust the shims (solid lifters) or clearance etc its not as straight forward as saying it has to be this or that. You need to measure the clearance between lobe on the cam and valve when the valve is shut with a feeler blade, find out what is should be and subtract the two figures to get the difference in spec. then either get shims to compensate and make up the difference or adjust the clearance till the correct spec is achieved. If you have to start messing about with shims then it gets quite involved. But if you willing its just simple maths to work out what you need. If you have hydraulic lifters then there is no adjustment they are self adjusting. Ka's are tappy as feck anyway, arnt the early engines based on a 1960's ford anglia engine
#4 |
S2 RST
It's mecanical tappets on a 97 Ka. Endura E engine. The way I've adjusted them before is just use the haynes recommended gapping when the valve is fully shut, ie rocker arm is up as far as it'll go. Just rock the car in gear to adjust them, simples
__________________
S2 RST |
#5 |
What he ^^ said they are solid lifters, the Endura E is a good reliable engine albeit old in design, yes it is basically a revamped Kent engine with engine management and FI. The Sport and Street are the only models to have a different engine that being the Zetec-Rocam. IIRC the new KA has a different engine.
Martin |
#6 |
![]() BANNED |
Depending on the mileage adjustment doesn't always makes then as quiet as they could be, this is due to severe rocker shaft wear, apply pressure to the rocker as you set the gap pulling the rocker up to take up any slack that exists.
You can also dismantle the rocker gear, take out the rocker shaft, turn so left is right right is left then rotate 180 degrees, will fit back perfect but this puts the unworn side on the bottom/underside where the pressure is so you have a "new" surface with no wear. tabetha |
#7 |
Piss easy to do, did them on my bird's old fiesta (same engine). If a chump like me can do it, anyone can!
__________________
#8 |
Trader Score: (1)
Rep Power: 33 ![]() |
Yeh easy to do.I used to do them on my escort and fiesta all the time.The way i did them is if the first tappet is on the rock adjust the last one no8 then get no2 valve/rocker on the rock and adjust the 7th valve/rocker.and so on.
__________________
![]() NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details. |
#9 |
the clearances are on the rocker cover think they are 0.20mm on inlet and 0.30mm on exhaust
__________________
cheeRS james i hope the above post was useful if not i will try harder next time if im in the mood ![]() wanted escort gti side skirts in red |
#10 |
Trader Score: (1)
__________________
#11 |
im pretty sure it is always used to look at the covers when working on them or getting bit in scrappy
__________________
#12 |
Thanks for the replies. It turns out the engine is a pushrod engine which suprised me a little but nice and easy to work on so it's sounds better than it did now
__________________
#13 | |
Quote:
Edit: IIRC anyway
__________________
#14 |
![]() BANNED |
| Display Modes | |
