PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 30-04-2010, 03:53 PM   #1
CoupeUK
Trader Score: (0)
CoupeUK has a spectacular aura aboutCoupeUK has a spectacular aura about
Default Making a rollcage out of exhaust tubing...?
Now i'm not going to start interforum wars but wanted to know whats everyones opinions of making a rollcage out of new exhaust tubing?
A lad on a local forum has had his local 'custom exhaust dealer' make up all the parts out of new exhaust tubing and they have been fitted by welded in/together by someone who fits cages for a living so I believe.
Some quotes from the progress blog:
Quote:
rofl, yeah its not proper roll cage tube, its moe for rigidity and looks
ok after having a chat with the lads, basically the difference between exhaust pipe and roll cage tubing is the thickness (obviously) and the alloy-steel ratio in the pipe,, but ill gurantee you its not exhaust pipe
Quote:
Just been to ????? and saw your car!
As much as i love you mate, but that's a disaster waiting to happen!!
The tube is too big as in diameter, it's not thick enough, that headbar (i called it a headbar cos that's what it'll have imprinted in it) should be further down towards the window.
As much as you say ????? has motor sport experience that stuff will bend with a slight prang.
Quote:
as said higher up its for rigity and looks, tbf i dont give 2 shits about it other than that
its made it no more dangerous, and trust me, it wont bend,
Quote:
You really shouldn't be able to hit you head on it. If you are going to hit it wearing a helmet then you'll still feel it, which is why any place you will bounce off it in an accident is covered in padding, but to have it close by in the event of a day to day accident it will cause you severe injury.
When I was stopped by VOSA, the first questions were "Who made the Cage?" and "Who installed the cage?"
Quote:
dont worry about the cage people, it looks cool as fuck and will never be as dangerous as the pug
Quote:
btw an omp cage is made of the same size tubing as mine and only has a fractionally higher steel grade, so i think everyone should stop jumping to conclusions over the quality and workmanship of this cage, as firstly none of u are qualified to make these statements, and secondly from what iv seen the 'custom exhaust place' are doing a bang up job.
thanku.
Quote:
???? says the diameter of the tubing is too big but yet its the same size as an actual OMP cage, so why is there an issue with my cage behind of 2" diameter??
and to suggest that the cage will bend with a slight prang is pretty much ludicrous.
Quote:
Looks Dangerous.
Oh well, just dont crash it and you'll be ok..... right?
Quote:
Dude, im not doubting the workmanship or the hours gone into the cage. It looks cool as fuck.
I'm only looking at it from previous experience at looking at cages in the flesh and into depths about them when i wanted to buy one/get one made.
And also, are you sure OMP cages are of 2inch diameter? If so, then yours certainly isn't 2inch.
An OMP cage is the same as mine (safety devices) and i'm pretty sure it's about an inch and half, and if it is 2, then yours must be bigger. Plus fractionally higher steel grade could be a massive difference in tubing, and i don't see OMP cages with seams in the bends either!!
Quote:
omp cages are 45 mm (i rang demon tweeks earlier)
my cage is 50 mm
also ill just leave this here
i think you'll see the diameter of this cage is pretty similar to mine, btw this cage costs £1700 i am not looking at spending this amount
one difference from this cage to mine is this one has box sections where it mounts to the floor, mine are being done with plates, also my rear diagonals are being welded down to the arches, and then a strut brace will be welded between the arches.
so your main concern is the seam in my tubes, as this picture shows the diameter is of no issue, i will ring ?????? tomorrow for some advice, but im quite sure, there will be no issues with what iv had done for what ill be using it for.
Quote:
The cage above is a completely different design, the front box section, the bit which takes the impact with a tyre wall is completely different.
Those curves in the upright don't look like they would protect you in an impact and that is the main concern, its not slating the 'custom exhaust place' but this isn't what they do. They aren't a motorsport prep place.
The cage isn't comparable to ???s, but then I guess that isn't the intention, however to say that its only slightly different in diameter and material but not accept that SD and Omp chose those specs after spending a great deal on r and d is slightly worrying if you then expect it to do the same job when/if you need it.
The cage looks good, but please get in your buckets and wave your arms & legs about, throw your self forward and get it padded. It won't look so good when you are eating through s straw and dribling down yourself.
Quote:
oh no im not comparing my cage to that one, just the tube diameter, bottom line is all manner of comments can be made, but there is only one way to test the cage, and when that happens ill be more conerned for my rear bumper
its being gusseted to the A and B pillars so body twist will be minimilized and it looks pimp so im happy, next up will be some uprated anti roll bars.
So whats your thoughts on this? As said I dont want to cause arguments but i'm wondering whether its dangerous or not, surely proper roll cage manufacturers go through lots of research and development when theyre designing a proper roll cage so it helps protect the occupants in an accident aswell as adding tothe overall strength of the vehicle....not a few lads designing a cage on the back of a fag packet in their lunch break?
By the way the vehicle in question is a 1.7 DTi Astravan on 18's, cambered to the hilt
__________________
<<<<Signature Removed>>>> PassionFord moderation at its best....
CoupeUK is offline   Reply With Quote
Old 30-04-2010, 03:55 PM   #2
timrud
Trader Score: (0)
timrud is an unknown quantity at this point
Send a message via MSN to timrud
Isn't exhaust tube quite easy to bend?
I helped my mate do a cage for his off roader, and the tube we used was not easy to bend!
TBH the guy sounds a complete retard
timrud is offline   Reply With Quote
Old 30-04-2010, 03:59 PM   #3
Mr S1
Don't ask - I don't know
Mr S1's Avatar
Trader Score: (2)
Mr S1 is an unknown quantity at this point
Exhaust tubing for a roll cage ?
Fuck that - I'd want solid steel like proper ones are made from.
__________________
Mr S1 is offline   Reply With Quote
Old 30-04-2010, 04:02 PM   #4
matts1
Trader Score: (0)
matts1 is on a distinguished road
surely it would be as much use as toilet roll tubes?
__________________
matts1 is offline   Reply With Quote
Old 30-04-2010, 04:05 PM   #5
badnews
badnews's Avatar
Trader Score: (0)
badnews is an unknown quantity at this point
ahahhahahha fooking nutter it will stiffen the car for sure but save you in a big crash i don't think so
badnews is offline   Reply With Quote
Old 30-04-2010, 04:08 PM   #6
vinnyvangough
Trader Score: (0)
vinnyvangough is an unknown quantity at this point
Send a message via MSN to vinnyvangough
I think he is gonna die
__________________
vinnyvangough is offline   Reply With Quote
Old 30-04-2010, 04:08 PM   #7
bythomson
bythomson's Avatar
Trader Score: (0)
bythomson is on a distinguished road
it would be as much point as a show cage would it not but as other have said id rather it was a full strength number not somethin else to impale yourself on should the wost happen
bythomson is offline   Reply With Quote
Old 30-04-2010, 04:12 PM   #8
Pete frst
Pete frst's Avatar
Trader Score: (0)
Pete frst is an unknown quantity at this point
still 10/10 for imaginative thinking in a difficult climate..........
Pete frst is offline   Reply With Quote
Old 30-04-2010, 04:23 PM   #9
fraser9764
fraser9764's Avatar
Trader Score: (3)
fraser9764 is an unknown quantity at this point
proper rollcage tubing is CDS, Cold Drawn Seamless tube.
exhaust tubing, and the stuff in that car, is not, you can clearly see the seams in the first picture. its just rolled plate welded up.
i can just imagine the dash bar for example, kinking in the middle when someone runs into the door, splitting at the weld, and stabbing someone in the guts
not to mention the gauge of the steel.
__________________
507.9bhp and 435lb/ft, Supra diff & 6deg rear beam
Mapped by TurboSystems and back end by 'a rs licker'
fraser9764 is offline   Reply With Quote
Old 30-04-2010, 04:25 PM   #10
v man
flint grey 2wd saff
Trader Score: (0)
v man is an unknown quantity at this point
pikey fucker
propper cage is only around 500 notes anyway
__________________
dump valves are for gays and the confused
v man is offline   Reply With Quote
Old 30-04-2010, 04:29 PM   #11
wirralphil
Trader Score: (0)
wirralphil is on a distinguished road
If the car was in a crash would the "cage" fitter be liable if it caused injury?
__________________
Quote:
Originally Posted by gaz s1 View Post
works for the ps3 but dont know about the council console
fpmsl
wirralphil is offline   Reply With Quote
Old 30-04-2010, 04:36 PM   #12
SteveB
Alloy wheel whore....
SteveB's Avatar
Trader Score: (1)
SteveB is an unknown quantity at this point
Send a message via MSN to SteveB
Should've popped down the Plumb Centre and made it outta plastic with the quick connector fixings..... would've been much eaier.!!!
Steve
__________________
www.focusrsparts.co.uk
SteveB is offline   Reply With Quote
Old 30-04-2010, 04:38 PM   #13
Neil@FastFord
Trader Score: (0)
Neil@FastFord is on a distinguished road
Quote:
Steve
You joke, but i have seen a Clio down Rochdale rocking that very look!
__________________
www.fastfordmag.co.uk
Team SHAKE N' BAKE
I know what naked girls look like, in real life!
Neil@FastFord is offline   Reply With Quote
Old 30-04-2010, 04:47 PM   #14
Graceland
Team HOTHOT!
Graceland's Avatar
Trader Score: (0)
Graceland is on a distinguished road
Quote:
Was that the same one that had a "cage" made up from pipe lagging foam before that?
__________________
Graceland is offline   Reply With Quote
Old 30-04-2010, 04:54 PM   #15
rsfido_1989
Trader Score: (0)
rsfido_1989 is on a distinguished road
surely the body roll will flex that and bend any fixed point and show kinks ?
rsfido_1989 is offline   Reply With Quote
Old 30-04-2010, 05:03 PM   #16
wirralphil
Trader Score: (0)
Pics needed of this Clio "Plumb" Edition.
__________________
fpmsl
Old 30-04-2010, 07:12 PM   #17
Steve the Plumber
The original Rouge Trader
Trader Score: (10)
Steve the Plumber is on a distinguished road
Just mad you should really notify your insurance company about this, so this will up your insurance premiums, but if you crash your car with your exhaust cage you wont get no extra protection from your exhaust cage! so being a total waste of time and money.
Surely it would of been cheaper just to buy a bolt in cage.
__________________
Steve the Plumber.
Steve the Plumber is offline   Reply With Quote
Old 30-04-2010, 07:20 PM   #18
orionmojo
orionmojo's Avatar
Trader Score: (1)
orionmojo is an unknown quantity at this point
This guy has me split on two on my OWN opinion . I'm having a roll hoop made for my cortina next week, its not going to be made of exhaust granted, but it won't be structural, just something i'm going to paint red and have it look good in place of the rear seats.
the guy says a few times its not structural, but does say "rigitdity" and looks, so doesn't really help himself. however i don't see how it can make the car that much more dangerous. if you have a crash violent enough to thrash you around in an old peugeot, an exhaust tube rollcage wouldn't be the most dangerous thing there i'd imagine.
Still a pleb though i think. make a roll hoop for show, not a full cage. ( or am i just trying to justify my own cage )
__________________
"If Sparks dont fly it rides too high!"
Member of "The Daytime pf talk bollocks and random shite club #5" - Mojo
orionmojo is offline   Reply With Quote
Old 30-04-2010, 07:21 PM   #19
RickyLee53
Trader Score: (0)
RickyLee53 is an unknown quantity at this point
Actually on the strength side, the MSA/blue bock states you can use 2" 2mm wall pipe. Normal exhaust tube is 2" 16 gauge. Which is 1.6mm so its not really "that" bad.
I'd be more concerned with the bends, they look pretty crushed in places, your only allowed to go 10% oval IIRC.
__________________
Fastest sohc and 1.6 civic in the uk. 4.7 to 60, 8.9 to 100, 12s at 119.6mph.
Fastest B16 civic in the UK, 11.26 road tyres. 10.5 on slicks. (pump fuel)
Most powerful bone stock b18, 416hp. Fastest B18 12.08 at 120.5mph.
10.9 second fwd on road tyres!
FWD TOTB 2009,2011 winners.
RickyLee53 is offline   Reply With Quote
Old 30-04-2010, 07:29 PM   #20
rubinsbin
Trader Score: (0)
rubinsbin is on a distinguished road
why not try copper tubing----------nice looking
rubinsbin is offline   Reply With Quote
Old 30-04-2010, 07:35 PM   #21
Steve the Plumber
Trader Score: (10)
Quote:
Not at the price copper is at the mo!
__________________
Steve the Plumber.
Old 30-04-2010, 07:38 PM   #22
snoopaloopa
Trader Score: (3)
snoopaloopa is an unknown quantity at this point
0.4mm is a huge difference when it comes to strength mate
snoopaloopa is offline   Reply With Quote
Old 01-05-2010, 12:11 AM   #23
RickyLee53
Trader Score: (0)
Quote:
It is a fair amount, 20% but this assumes the material grade is the same. I'd take a 1.6mm t45 cage over a 2mm cds.
__________________
Old 01-05-2010, 12:53 AM   #24
OldDan
OldDan's Avatar
Trader Score: (0)
OldDan is an unknown quantity at this point
Send a message via MSN to OldDan
schedule of the pipe wouldn't be think enough I don't think.
__________________
"On that occasion I said to him 'why do you do a tackle like that?' And he said 'because I don't like you'.
Patrice Evra speaking of tussles with Super Kevin Davies.
OldDan is offline   Reply With Quote
Old 01-05-2010, 01:11 AM   #25
Paulo P
Paulo P's Avatar
Trader Score: (0)
Paulo P is on a distinguished road
Quote:
Oh well, one less dangerous retard in the world to worry about The guy clearly won't listen so sit back and watch him dig his own grave, he's going to need it soon
I've seen the way "show" cages react in a crash so that shit is a real no no, I would feel safer in a car with no cage than that shit
__________________
Paulo P is offline   Reply With Quote
Old 01-05-2010, 04:20 AM   #26
botters
competant bodger
botters's Avatar
Trader Score: (0)
botters will become famous soon enough
i make exhaost at my work and have done for many years i use 2mm thick 304 stainless and i know if a bend aint quite thick enough instead of walking back to the bender i jam one end to the floor and bend the other end a peice of piss till it fits i qwould massivley fear for my life if i was to use this for a cage, a mate once asked me to make one for me, i showed him the bend difference between cds and 04 of the same wall thickness and basically at 6 ft and 17 stone i can hang of a piece of cds and it hardly bends whearas t304 will almost bend in half lol! so in short antone makig a cage out of exhaust tube will die should the worst happen
botters is offline   Reply With Quote
Old 01-05-2010, 08:19 AM   #27
dojj
Resident Wrestling Legend
dojj's Avatar
Trader Score: (3)
dojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the rough
what i would have put if:
i'd know what the name of it was
i'd got here first
that's a deathtrap waiting to happen because he'll think it's much safer when in actual fact it's making it more unsafe than wihtout the cage in it
dojj is offline   Reply With Quote
Old 01-05-2010, 09:14 AM   #28
steviecossie
steviecossie's Avatar
Trader Score: (0)
steviecossie is an unknown quantity at this point
Send a message via MSN to steviecossie
good luck to him when he rolls it, idiot.
__________________
R.I.P Colin McRae (a motorsport legend)
WR1 sold, time for a MK2 FRS
steviecossie is offline   Reply With Quote
Old 01-05-2010, 09:14 AM   #29
focusv8
Trader Score: (0)
focusv8 is an unknown quantity at this point
If he went from exhaust manifold into the front of the cage, then out the back of the cage to a silencer then;
1, It would save a considerable amount of weight being able to loose the front half of the exhaust.
2, It would save even more weight as he could bin the heater and use the heat off the tube to keep warm.
Hang on better idea, just pipe the exhaust straight inside the car that'll keep the gene pool clear of idiots like these.
focusv8 is offline   Reply With Quote
Old 01-05-2010, 09:49 AM   #30
Billy_RS
Sierra RS Cosworth Owner!
Billy_RS's Avatar
Trader Score: (2)
Billy_RS is an unknown quantity at this point
If your gunna do it, do it properly!
__________________
Cheers Billy
Billy_RS is offline   Reply With Quote
Old 01-05-2010, 09:58 AM   #31
Chip
*** Sierra RS Custard ***
Chip's Avatar
Trader Score: (3)
Chip will become famous soon enoughChip will become famous soon enough
What an enormous amount of effort to go to just to end up with something not worth having.
Got all the downsides of a rollcage like hurting if you whack your head off it but no doubt without adding much useful strength.
Strange person.
__________________
Sometimes its more fun not to care if things make sense, and just do them anyway!
Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff
2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused
www.VauxSport.com
Chip is offline   Reply With Quote
Old 01-05-2010, 09:59 AM   #32
dlatch
Zetec locost driver
dlatch's Avatar
Trader Score: (0)
dlatch is an unknown quantity at this point
it will be a cosmetic cage rather than a safety cage
__________________
I drive a citroen
dlatch is offline   Reply With Quote
Old 01-05-2010, 10:02 AM   #33
Brian
Trader Score: (2)
Brian is an unknown quantity at this point
Wish i had seen this before, would of saved me paying out for a Safety Devices full rollcage
Brian
__________________
Brian is offline   Reply With Quote
Old 01-05-2010, 10:10 AM   #34
Mr.T
Mr.T's Avatar
Trader Score: (0)
Mr.T will become famous soon enough
Send a message via MSN to Mr.T Send a message via Skype™ to Mr.T
This is allmost like the shed Chip made Looks ok but you don't want something happen to it
__________________
Saab 9-5 '98. 2.0T. Maptun Stage 1 225hp 340nm
Youtube coment:
Quote:
boosting a civic is like having butt sex. it never feels right
Mr.T is offline   Reply With Quote
Old 01-05-2010, 10:11 AM   #35
Mr.T
Mr.T's Avatar
Trader Score: (0)
Quote:
Now this is just stupid. Where are you going to leave your case of beer
__________________
Youtube coment:
Old 01-05-2010, 10:14 AM   #36
Billy_RS
Billy_RS's Avatar
Trader Score: (2)
__________________
Cheers Billy
Old 01-05-2010, 10:52 AM   #37
pee vee
pee vee's Avatar
Trader Score: (0)
pee vee is an unknown quantity at this point
There is a 106 gti around this way with exhaust tubing.
__________________
Focus RS number 1215.
pee vee is offline   Reply With Quote
Old 01-05-2010, 10:53 AM   #38
foreigneRS
Testing the future
foreigneRS's Avatar
Trader Score: (0)
foreigneRS is on a distinguished road
that is really the only point of concern. the diameter, thickness etc, is not really a consideration, it's the splitting along the weld that is dangerous
__________________
Nick
It takes me less than 9 minutes
RP Lab L8 ECU
1998 Puma 1.7 / 2002 Galaxy 2.3 LPG / 2007 Honda VFR800 VTEC / 1972 Honda C90
foreigneRS is offline   Reply With Quote
Old 01-05-2010, 11:08 AM   #39
CoupeUK
Trader Score: (0)
Did I mention this cage is in a 1.7DTi Van?
Yeah thats right.....TRACKVAN
__________________
Old 01-05-2010, 11:50 AM   #40
Chip
Chip's Avatar
Trader Score: (3)
We featured a diesel astra van in Total Vauxhall thats does the ring in under 8:40, faster than most people on here in their trackday cars
Vans are stripped out in the back, no heavy glass etc, no real disadvantage to the shape either as proved by the T5 touring cars, when you are talking about a van like that astra which is just an estate with no windows basically.
__________________
www.VauxSport.com
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
