| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
1968 Mk2 Cortina - Zetec turbo - 329bhp at 14psi so far... Classic Fords FTW! |
#2 |
escort mk4 cossy 4x4
gripper will make you a diff if there is a market for them.
__________________
#3 |
kaaz do a platted diff for the mtx75, will be shit on the road though
__________________
If your not going sideways then your not pushing hard enough!!! ^^^That includes FWD 8) ^^^ |
#4 |
__________________
#5 |
__________________
#6 |
try torsen/ford racing
#7 |
__________________
#8 |
Looking at Kaaz diffs but they are about Ł1k with fitting. Don't mind paying a bit but that's a bit much for a diff.
Might be welding it after all!
__________________
#9 |
Do Tran-x do one?
__________________
Dan. ![]() M.A.Developments 500 spec engine, GT30, Autronic, 1000cc injectors, ST Inlet ETC..... |
#10 |
weld it as a welded diff isn't going to be much if any worse than a plated
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
#11 |
a welded diff would be horrendous in a FWD! it just wouldn't turn, plated has got some give in it!
__________________
#12 |
the one i drove in a gravel spec nova a few years back didn't turn either on tarmac!
__________________
#13 |
As Rick says after reading reviews I can't seeing it being much worse if at all. I've heard welded diffs on FWD can pop CV joints out on tight turns but can't really see that. I've heard of others saying they've experienced it and isn't that bad
__________________
#14 |
i used to race a mini with a welded diff, it worked ok on the corners provided you where going fast,but if you had to stop mid corner, you had to spin the wheels to get it going again.and tyre wear was excessive.the way to drive it was to slide the rear end round.hard rear set up.
with a plated diff,you can adjust the preload to make it more road useable.ie it doesnt lock as easily. but that kind of defeats the object if you are after 1/4 mile times.
__________________
#15 | |
Quote:
#16 | |
Quote:
bought 2 4x4 cossys to break for spares with the procedes. i had a trade stand with my mate at central day.
__________________
#17 | |
Quote:
#18 |
__________________
#19 | |
Quote:
__________________
#20 |
__________________
#21 |
I've driven 3 Road rally cars with plated diffs, you can run at them at different levels of lock though, all 3 turned in very well on tarmac, but where a constant battle and not a pleasureable drive!
__________________
#22 |
I have looked into plated diffs before I bought my cts, there is a lot of adjusting which needs to be done especially when the internal clutch plate wares. These diffs were designed to be removed and adjusted between each rally stage to suit the stage conditions, not really practical when used on a normal road going car. If you are thinking of welding the diff up for a road car be prepared to go through plenty of drive shafts and bottom arms
I got this info from quaiffe as I was looging at one of their old plated items which came up on ebay a while back.
__________________
Kind regards Raj Please use the above methods for contacting us as PM's are hard to keep track of
#23 | |
Quote:
Cant see driveshafts and bottom arms being a problem really.
__________________
#24 |
Did you drive the car? ive been in a mk1 rwd escort with welded diff and it was terrible, as for drive shafts the wheel hub spline will be wanting to rotate differently to the gearbox spline so this will incurr a lot of stress, either way it will put stress on the drive shaft or the suspension. Ive never been in a fwd drive car with a welded diff so you probably know more than me, I would of thought it would be more hastle than benifit as traction is only improved in a straight line, the car would be encouriged to spin as soon as you turned the wheel which is not ideal at all for a fwd car. If its for the drag strip then maybe it could work well???
__________________
#25 |
It will be for the strip so may just see what it's like.
I used to have a welded diff on my RWD Cossie and didn't find it half as bad as people said it would be. Easily lived with it, it was only VERY tight turns you noticed it at all, and the rest of the time it was arsing out anyway
__________________
| Display Modes | |
