PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 15-03-2010, 12:30 PM   #1
mk1sierra
Trader Score: (0)
mk1sierra is on a distinguished road
Exclamation URGENT HELP NEEDED rs turbo still not starting
hi guys i need some help right i replaced the relay still nothing connected up another battery to the fuel pump n the car was running like that off the battery the thing i done get is when i check the positive on the fuel pump its comming up as a negative if some 1 can tell me pleaseeee
mk1sierra is offline   Reply With Quote
Old 15-03-2010, 12:33 PM   #2
ECU Monitor Enthusiast
Trader Score: (1)
ECU Monitor Enthusiast will become famous soon enough
The pump will only run when the car is being started or running.
It may pulse on for a few seconds when the ignition is turned on.
Where are you measuring the voltages from ? (Where are you putting meter leads)
ECU Monitor Enthusiast is offline   Reply With Quote
Old 15-03-2010, 12:39 PM   #3
mk1sierra
Trader Score: (0)
the thing is the pump isnt even making a noise even when i try 2 start it :s
im putting meter on the leads at the fuel pump itself and then getting a reading from the relay area but the meter is telling me that the positive and negative are both negatives when the cars ignitions is on???
Old 15-03-2010, 12:43 PM   #4
mk1sierra
Trader Score: (0)
WOOOOP she started up cheeRS 4 ur help mate
Old 15-03-2010, 12:44 PM   #5
Trader Score: (1)
You wont get a positive at the pump until it needs to run.
Is the fuel pump fuse ok ?
The relay should "click" when you try to start the car although it may be hard to hear it !
If the relay doesnt activate then there could be problems withteh distributor sensor and/or power to the silver ecu as teh relay gets the output of this sensor in order to drive the fuel pump relay.
You can check the power to the dizzy sesnor by putting a meter accorss the 2 outer pins on the connect. You should see 12 volts with the ignition on.
Old 15-03-2010, 12:51 PM   #6
mk1sierra
Trader Score: (0)
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
