PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 14-03-2010, 08:56 AM   #1
RS Classics
Trader Score: (0)
RS Classics is on a distinguished road
Itz All Odds
Default wierd sierra cosworth problem help! take 2 HELP
if you read my other post my sapphire is a wierd starter. some times it goes first time you turn it over then it can take ages for it to start. so i tried a p8 in it and it starts fine first go every time but boosts wierd so i put another l8 in that we had and it does the same thing as the other l8. runs fine when it runs but takes an age to start sometimes. is it just the l8 ecus that do this or is it a fuel pump prob or something??? help please
RS Classics is offline   Reply With Quote
Old 14-03-2010, 09:53 AM   #2
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Trader Score: (12)
Stu @ M Developments will become famous soon enoughStu @ M Developments will become famous soon enough
Quote:
Its almost always a Crank or Phase sensor problem. Usually phase.
Stu @ M Developments is offline   Reply With Quote
Old 14-03-2010, 09:54 AM   #3
RS Classics
Trader Score: (0)
Itz All Odds
have changed them all before. the wierd thing is is that the p8 worked first turn every go? its a lambda sierra
Old 14-03-2010, 10:04 AM   #4
RS Classics
Trader Score: (0)
Itz All Odds
Quote:
have changed them all before. the wierd thing is is that the p8 worked first turn every go? its a lambda Sierra
Old 14-03-2010, 10:24 AM   #5
Trader Score: (12)
Check the alignment and gaps. Its the fact that your P8 works that is directing me to those sensors, but I dont currenty have time available to explain why that is.
Old 15-03-2010, 07:47 AM   #6
RS Classics
Trader Score: (0)
Itz All Odds
does the p8 work differently with the gaps
Old 15-03-2010, 09:24 AM   #7
prius
Super Moderator
Trader Score: (5)
prius is an unknown quantity at this point
the p8 has a very clever function called error mask
__________________
Perfic
prius is offline   Reply With Quote
Old 15-03-2010, 09:33 AM   #8
RS Classics
Trader Score: (0)
Itz All Odds
Quote:
huh really could you explain this because it would be very interesting to know about
Old 15-03-2010, 11:16 AM   #9
Toe Knee
Toe Knee's Avatar
Trader Score: (2)
Toe Knee is an unknown quantity at this point
Send a message via MSN to Toe Knee
at an uneducated guess the P8 isnt as fussy about the gaps being 100% right as the L8 is and compensates for it.....
__________________
Toe Knee is offline   Reply With Quote
Old 15-03-2010, 11:37 AM   #10
ECU Monitor Enthusiast
Trader Score: (1)
ECU Monitor Enthusiast will become famous soon enough
Allow me Stu...
The P8 has better signal processing amplifiers on the sensor inputs and is more tollerant to noisy and/or low voltage inputs.
Low voltage output from the crank/phase sensors can happen as they age or the gaps are wrong.
I.E. The older ecu's require a clearer stronger signal over the P8.
Tony is probably busy so allow me...
This is a function where the ecu software tracks the normal sensor inputs.
If one or the other fails, the ecu can continue to run normally as it knows where it was (or should be) so assumes it can carry on the same sequence of events.
However, this normally triggers a limp home mode so the car can still be driven but at a reduced RPM or boost level to prevent possible engine damage from incorrect ignition timing positions.
ECU Monitor Enthusiast is offline   Reply With Quote
Old 15-03-2010, 08:48 PM   #11
RS Classics
Trader Score: (0)
Itz All Odds
So that would explain the weird boosting and idoiling in the p8
Old 15-03-2010, 10:43 PM   #12
Trader Score: (1)
Its more likely the chip you have for the P8 is less suited for your engine that the other.
Old 16-03-2010, 01:09 PM   #13
prius
Super Moderator
Trader Score: (5)
Quote:
Originally Posted by Flux Capacitor. View Post
Allow me Stu...
If The P8 goes into Limp home it will limit rpm to 4000 rpm
__________________
Perfic
Old 17-03-2010, 07:40 AM   #14
RS Classics
Trader Score: (0)
Itz All Odds
the sensors are all new all spaced correctley and still the same. runs fine just doesnt start good. and is extremely annoying
Old 17-03-2010, 09:40 AM   #15
Trader Score: (1)
Ignoring the ecu types for one moment, the chips for both will be different even though they may be for the same engine setup and state of tune.
It does sound like to me the chip in the L8 may need extra fuel for starting in the map !!
Old 17-03-2010, 09:43 AM   #16
RS Classics
Trader Score: (0)
Itz All Odds
i had a standard l8 in it that its always had never EVER opened and at the moment i have a different chipped one in it for more power but both the l8s start the same.
Old 17-03-2010, 09:54 AM   #17
Trader Score: (1)
So are you saying one of the L8's is totally original, and the other has an uprated chip ?
What state of tune is your engine ? (map sensor type/ injectors/cams/turbo etc... )
Old 17-03-2010, 10:35 AM   #18
RS Classics
Trader Score: (0)
Itz All Odds
Yep and both do the same. As for the engine all standard for a 4x4. Brand new engine done about 700 km
Old 17-03-2010, 10:54 AM   #19
Trader Score: (1)
A quick experiment to try...
Disconnect the vacuum hose from the fuel pressure regulator....
Does the car start up quicker and idle better ?
(This should enrich the fuel slightly during starting)
Do not drive the car like this !
Old 12-04-2010, 06:32 AM   #20
RS Classics
Trader Score: (0)
Itz All Odds
turns out it was the knock sensor. the wire must have been shorting out on the body somewhere because the wire was split
Old 12-04-2010, 11:43 AM   #21
PAUL S
PAUL S's Avatar
Trader Score: (5)
PAUL S is an unknown quantity at this point
goes to show all the above fellas know there stuff, they all quickly said crank sensor issue of some kind or another
handy info to know
PAUL S is offline   Reply With Quote
Old 12-04-2010, 04:28 PM   #22
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
glad its sorted fella.
Glenn. is online now   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
