PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 26-02-2010, 02:59 PM   #1
20fiesta09
Trader Score: (0)
20fiesta09 is on a distinguished road
Default cant get my clutch too bleed
i have a mk5 fiesta (needed new clutch so relpaced with pressure plate and new slave cylinder)
everythings back together and i went too bleed the clutch and cant get it too bleed
has anyone else had this problem or have a idea whats corseing the problem ?
20fiesta09 is offline   Reply With Quote
Old 26-02-2010, 04:30 PM   #2
Burnzybubbles
Bubbles
Burnzybubbles's Avatar
Trader Score: (0)
Burnzybubbles is on a distinguished road
Are you using a pressure bleeder it'll make life alot easier you can do it without but your timing has to be spot on and is a bit long winded, halfords have them worth there money for jobs like this
__________________
mk5 esco dead
Burnzybubbles is offline   Reply With Quote
Old 26-02-2010, 04:54 PM   #3
20fiesta09
Trader Score: (0)
no mate but will go too halfords to-morrow and get 1
Old 26-02-2010, 04:58 PM   #4
Chris Honeywell
Chris Honeywell's Avatar
Trader Score: (0)
Chris Honeywell is an unknown quantity at this point
Had the same trouble with my ferrari when i replaced the clutch.
Halfords pressure bleeder will do the job in no time just make sure u put a load of fluid through to make sure there is no air left in the system
__________________
Ferrari F355 owner
Chris Honeywell is online now   Reply With Quote
Old 26-02-2010, 05:47 PM   #5
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
modern technology lol. What i do when i change clutches on modern cars is i fill the slave cylinder with brake fluid then normaly the pedal is ok. Try getting an old oil can. (The ones where you use your thumb to get the oil to come out) put it on the bleed nipple and fill the oil can full of brake fluid and pump the fluid into the nipple. I hope you havent nackered the master cylinder.
Glenn. is offline   Reply With Quote
Old 27-02-2010, 08:57 AM   #6
20fiesta09
Trader Score: (0)
cheers evryone , going out too have anthor go at bleeding it !
Old 27-02-2010, 05:13 PM   #7
Glenn.
Glenn.'s Avatar
Trader Score: (1)
well let us know what the crack is. I did a transit connect a few weeks ago and i fooked the clutch master cylinder.
Old 27-02-2010, 05:21 PM   #8
botters
competant bodger
botters's Avatar
Trader Score: (0)
botters will become famous soon enough
can be a bit of a pain to bleed but if you get a mate operating the bleed nipple you shouldnt be too bad just the first lots of air can be bad to get out because the pedal will keep staying on the floor. i myself have stopped using pressure bleeders on clutches as ive once had a slave cylinder pop and had to take box out again! probably not the bleeders fault but i cant risk it with how busy i am!
botters is offline   Reply With Quote
Old 27-02-2010, 05:34 PM   #9
rspickup
Trader Score: (0)
rspickup is on a distinguished road
Get the pressure bleeder kit that runs off a spare tyre, then you can do it at low pressure
__________________
rspickup is offline   Reply With Quote
Old 27-02-2010, 05:45 PM   #10
RichieST
RichieST's Avatar
Trader Score: (2)
RichieST is on a distinguished road
Send a message via MSN to RichieST
Isn't the recommended way to do these via reverse bleeding, as in pump the fluid through the bleed nipple up to the reservoir?
__________________
RichieST is offline   Reply With Quote
Old 27-02-2010, 06:20 PM   #11
jameswrx
Trader Score: (0)
jameswrx is an unknown quantity at this point
May be an idea to make sure the bleed nipple is at the highest point, some slaves have it on the side and the air goes up to the top of the cylinder and sits there.. all the messing about does nothing. You need to unbolt it and get someone to hold it so the nipple is the highest point of the slave (usually requires turning it on its side) amd any air should make its way to the high spot.
jameswrx is offline   Reply With Quote
Old 27-02-2010, 08:01 PM   #12
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Quote:
Thats what i mean and im on about. We do this at work. Ive done clutches twice on ford connects and ive filled the slave cylinder with fluid before ive put the box back in. Ive never had to bleed the clutch either.
Old 28-02-2010, 10:11 AM   #13
20fiesta09
Trader Score: (0)
got the bastard too bleed after 25 notes later !
got a gunson easy bleed that goes on the spare wheel ect ... done it in 2 mins.
cheers people !
Old 28-02-2010, 10:26 AM   #14
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Ha ha nice one.At least its done now.You will have to go and pump your tyre up now.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Old 12-03-2010, 01:01 PM   #15
Reddicap
Trader Score: (0)
Reddicap is on a distinguished road
Hi, I'm having difficulty getting a mk 5 fiesta to bleed. I'm using a vacuum bleeder but it seems all i've done is suck all the fluid out! And yes, the master cylinder is full.
What the hell am i doing wrong? Pumping or sucking, we can't get any fluid to come through.
Any ideas guys?
Reddicap is offline   Reply With Quote
Old 12-03-2010, 04:02 PM   #16
Reddicap
Trader Score: (0)
Sorted it, thanks to eezibleed.
Old 12-03-2010, 04:24 PM   #17
Burnzybubbles
Bubbles
Trader Score: (0)
cheers people !
you went to halfrauds in the end then .
but it's £25 out your pocket now but it'll save you loads of time in the future
__________________
mk5 esco dead
Old 12-03-2010, 04:30 PM   #18
Glenn.
Glenn.'s Avatar
Trader Score: (1)
is the fluid just spitting out if so the master cylinder might be fooked..
Old 12-03-2010, 04:32 PM   #19
Burnzybubbles
Bubbles
Trader Score: (0)
glen read the post above mine i have an inkling he might of sorted it
__________________
mk5 esco dead
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
