| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
![]() BREAKING MY ZETEC TURBO ESCORT!!! MK1 Escort wanted!!! |
#2 |
Super pussy eater
what slave cylinder are you using for the clutch?
as if its an AP one, the bleed nipple points to the floor, not up like normal |
#3 |
Super pussy eater
as in the cylinder that moves the clutch plate
#4 |
running a standard one as my mate used my new one in his
__________________
#5 |
Super pussy eater
got any pics?
standard off what? |
#6 |
sorry its an st170 box/setup with a compbrake pro pedal box set up, what you wanting pics of?
__________________
#7 |
Super pussy eater
ah right, thought you had done a hydraulic clutch conversion for some reason..?
i have never bled the 170 cylinder before so cant help really. do you have any pics of the setup at all tho, as i may be able to suggest something. |
#8 |
its in my mk3 escort, best pics i have atm:
__________________
#9 |
Super pussy eater
i take it the bleed nipple is the bit with the spanner on?
is it all connected up right to the slave cylinder? are you using a pressure bleeder or just the pedal? and what happens if you just open the bleed nipple and leave it, does fluid come out? |
#10 | |
Quote:
__________________
#11 |
bump
__________________
#12 |
#13 |
Rock Out!!
I'm not an expert, but reading the details, makes me wonder if the actual master cylinder is ok. The hydraulic clutch is just a sealed tube filled with fluid, if after all that pumping there is no pressure, but no puddle of fluid somewhere then maybe it is being pushed into the resevoir when you lock the nipple at the slave end. If I'm way off the mark, then apologies, as i'm used to working mine which is just a master, pipe, slave arrangement.
#14 |
Capt Chaos
i take it your using compbrake pedal box ? there cylinders are crap all three of mine leak into the car going to swop to girling cylinders this year .so it could be dodgy cylinder .hope this helps
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,, ![]() ![]() TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION Clicky |
#15 |
I have a similar problem with my rear brakes too, I cant get them to bleed and havent got a pressure bleeder either. I changed to a new Girling master cyl and it was even worse- I must have trapped more air in the line?. If you are getting air bubbles out of the pipe still then it still isnt bled fully yet I would think? I may have to invest in a pressure bleeder to sort it as I didnt have a h.brake or rear brakes, and as I have a bias box too- no front brakes till late in the stroke either.
__________________
MSD L8, 1/4mile 14.3@98MPH 2.3sec-60ft on 11PSI-260BHP? And 10 yr old rubber. COSSIE ON ICE http://www.youtube.com/watch?v=RwPZDlY7Z0A |
#16 | |
Quote:
. just done soo much bleading on the clutch i dont know how it can still have air in it as front brakes was much quicker???
__________________
#17 |
sounds like still trapped air the easiest way to bled these is to flick top of the peddle no more than 2cm not full strokes it helps dislodge trapped bubbles and wastes less fluid. After about 5mins flicking the pedal and bubbles stop then start to do the bleed nip up until it just closes then do few full strokes as resistance builds up sure sign its working.
#18 |
will give it another try in the week or weekend when i next have free time and a spare pair of hands lol. cheers guys
__________________
#19 |
Super pussy eater
is the mate thats helping shutting the nipple properly before you lift your foot lol? i usually get the mate to pump the pedal lol.
my pressure bleeder wont seal on my pots either, so that has to be done manually. one of the few jobs left that need to be done on my 3dr is to bleed the brakes... |
#20 | |
Quote:
__________________
#21 |
well.... tried again, had lil chat with crazycage and suggested some options, adjusted pedal for more travel, pump pedal 5-6 times then release nipple and still nothing after 15-20 mins
, buggered master? getting sick and tired of the car now, so just wish i could bring myself to sell it at times lol
__________________
| Display Modes | |
