| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
the smiley one ;)
__________________
Wheres my monkey ? |
#2 |
the smiley one ;)
BUMP
__________________
#3 |
having all the extra boxes does not help power or help the turbo spin up!however if you got a particular filter and you remove it your management system will not like it too much!you might also have to put a different turbo on it etc
__________________
![]() 416.1bhp STORMTROOPER I am the real doug! |
#4 |
Dont worry there will not be any sensors in the exhaust so you could complete remove the exhaust and the car would not flash up any lights.
Why not just have a straight through pipe with a back box then? Basically just decatting the car. Thats what i am about to do with my car, got a full turbo back Milltek exhaust with no cat in it.
__________________
#5 |
If you have a car with a DPF, like the 170bhp Golf, they are a bit funny about been remapped I think?
#6 |
the smiley one ;)
What im trying to ask is instead of just straight pipe I WANT the DPF in the system along with a silencer. I dont want a loud smokey diesel car. However if it hinders performance im prepared to lose them.
They are fine with being remapped.
__________________
#7 | |
Working or sleeping
Quote:
#8 |
What year is your Passat?
__________________
#9 |
I have heard a few stories about 170's literally going up in flames after a remap. Obviously the lower power cars don't suffer the same way as it is a different setup..
#10 |
silensers will loose performane, they restrict the exhaust flow which is why they quiten it down.
id just have a back box, the filter and cat, 2.5" pipe work. you could ditch it all i beleive but itd be a loud, and youd get pulled alot for it with the noise |
#11 |
its not as easy just too lose a particular filter!
__________________
#12 |
and its a diesel... who the f**k wants a loud diesel?
What age is the car? JAmes. |
#13 | |
Quote:
#14 |
Jamsport have a lot of files suitable for removing DPF's now
__________________
#15 | |
Quote:
when we remove the DPF we refit all the sensors into the exhaust like you would with lambda sensors when decatting a car. There have been one or two stories about remapped dpf cars setting on fire etc, this was the case when people were pushing too much power thru the dpf fitted cars ,they then blocked up and over heated. we have remapped many cars with the dpf still fitted and not had a problem |
#16 | |
Quote:
Over heating the DPF will cause the brick inside to crack, and then hence block |
#17 | |
Ford for life
Quote:
a friend did this to his golf and it was gutless as hell, something to do with turbo diesels needing back pressure (he4 removed every box inc cat and had a straight through pipe), it was a golf gt tdi 150. my citroen c4 vts 2.0 hdi i used to have had been remapped and within a month the dpf needed replacing, one morning the obc said dpf fluid low (still had 3/4 of a bottle of fluid left), next morning it would not start, the dpf had melted and the dpf ecu was fubbered, not sure if the remap caused it or not though but i know Ł780 later it was ok again but occasionly when driving at one set speed on the motorway for a prolonged time it would start feeling a bit lifeless (had 169 bhp and 262 lb/ft) then when you dropped a gear and floored it ridicolous amounts of soot and smoke would pourfrom the back then it would be ok again, the dpf was clogging so i was told, again not sure if this was due to the remap but before that it was fine, could maybe just be down to the fact it was a citroen lol Last edited by mozzy; 16-02-2010 at 09:05 AM. |
#18 |
Mozzy - who did your remap?
__________________
![]() "Judging by the car you have chosen, you are a motorist of a special breed, and you are probably no novice when it comes to automobiles." . . . 928 S4 Owner's Manual 1987 |
#19 | |
Quote:
#20 |
Ford for life
http://www.southwestincartech.co.uk/...FSGElAod8WkQYQ
just noticed they are doing dpf removal and decoding now Last edited by mozzy; 16-02-2010 at 04:17 PM. |
#21 | |
Quote:
Presumably the German stuff only runs Can !!! |
#22 |
Important thing is that a DPF car has to be mapped very carefully. If it runs too rich, the filter will be full in no-time.
So you can't say I want the filter to avoid smoking out of the exhaust as that's not really what it's there for. They only work when the car burns its fuel reasonably clean in the first place.
__________________
![]() Original picture by Quax |
#23 | |
Quote:
TDi's have a few sensors in the exhaust if they have the particulate filter. normally you have a pair of pressure take off either side of the filter also to go to a pressure differntial sensor to tell the management that the filter is blocked etc. |
#24 |
PassionFords Creator
![]() ![]() ![]() Trader Score: (12)
Rep Power: 36 ![]() ![]() |
DPF's are very commonly blocked when remapping is done by people who have all the gear but no idea... take care out there folks.
__________________
Best Regards, Stu . Click here to read my tuning articles. . Click here to visit our Brand NEW webshop. Find us on FaceBook. |
#25 |
I've remapped LOADS of DPF equipped cars and not a problem so far (touch wood!)
__________________
#26 | |
Quote:
DPF's only came out on later cars, as the guy said in the first post, he has a Passat TDI, so i am guessing upto 2005? Therefore will not have a DPF. The 1.9 TDI engines that came in MK4 Golfs/Boras etc etc dont have any sensors in the exhaust, well my car hasnt as i looked into this before ordering my Milltek. http://i901.photobucket.com/albums/ac218/ant130/002.jpg Standard exhaust on the left, see any sensors? Nope. This is the type of exhaust Mr Passat will have on his car, so doesnt have to worry about DPF's.
__________________
#27 | |
Ford for life
Quote:
haha you basically just repeated what XRSI wrote, read what he wrote again then recomment cause you said basically the same thing which must mean if he is wrong then so are you. on a different note i am guessing thye guy that mapped mine did a poor job cause although it went like stink the dpf clogged all the time, a good hammering cleared it out again but never lasted long, this was on a 2.0 16v psa hdi though not a pd. i know when i had a golf tdi 170 courtesy car from helphire which had 1200 miles so basically brand new it was constantly saying dpf fault on the obc |
#28 |
Ooooopppssss!
"...in the exhaust if they have the particulate filter..." I was right in what i first said though....
__________________
| Display Modes | |
