| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
![]() BANNED |
#2 |
the ex's (say ex, current partner but seperated at min) KA does this...
was going to look at it but couldnt be arsed, i assumed it was bad sealing round the screen. |
#3 |
Zetec locost driver
would poss get leak if screen is a replacement, also try putting a very bright light shining towards the bulkhead and check from inside anywhere u can see light coming through, leaks are a right pain to track down sometimes
__________________
![]() I drive a citroen |
#4 |
im a screen fitter and its quite common on these..also under and around the scuttle is prone to corrosion and causes leaks under the glass
#5 |
Theres a bit grommet on either side of the engine bay towards the rear behing the header tank (left or right depending on engine) that perrishes or if the car is second hand, someone might have stuck some cabling down. Leaks like a f00ker, even if its only a tiny little crack in it.
hth JAmes. |
#6 |
![]() BANNED |
HI,
I did wonder about the screen, but it is the oe one SEKUR IT job, think it's rip the car to bits time, thanks for suggestions. tabetha |
#7 |
ZETEC TURBO
the air con drain tube is by the centre consal, ive had loads where they come out and fill the car up
#8 |
![]() BANNED |
Thanks for that, about the air con pipe, I didn't even know you could get air con on these, even has leather!!
tabetha |
| Display Modes | |
