PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 28-01-2010, 05:19 AM   #1
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
Default mk 5 fiesta 1.25 16v timing belt.
hi people just wanna know which way is the easiest way to do a timing belt on these engines. Or how do you do them. I should be getting the timing pins from a lad at work. Just after some tips really cause the car is 10 years old and the mileage is nearly at 80.000. My wife will be starting a new job soon and she will be doing more miles so i dont want it snapping on her. Hopefully i will be doing it next weekend.
Glenn. is offline   Reply With Quote
Old 28-01-2010, 05:48 AM   #2
wirralphil
Trader Score: (0)
wirralphil is on a distinguished road
What ever you do, don't forget to change the tensioner. Regardless of how it looks, these can fail quite easy.
wirralphil is offline   Reply With Quote
Old 28-01-2010, 07:37 AM   #3
coco16i
coco16i's Avatar
Trader Score: (0)
coco16i is an unknown quantity at this point
Just be sure to use the correct timing pin for locking the crankshaft, the crank pulley is not keyed onto the shaft and also the timing belt drive pulley on the crank is not keyed so you can turn the crank and alter the valve timing with the crankshaft pulley bolt removed (even with the belt still on and tensioned)
Use the locking bar to hold both camshafts in place but dont rely on just that when loosening the camshaft sprocket bolts as you can very easily snap the end lugs off the shafts ! Get a spanner or self grips and hold each shaft in turn while looseining the bolts, also be sure to use thread lock when refitting them and on the crank bolt.
Not a bad job to do really.
coco16i is offline   Reply With Quote
Old 28-01-2010, 04:17 PM   #4
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Sounds scary to me fella.Im starting to get worried about doing it now.Ive bought a timing belt kit which is the belt and the tensioner.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Old 28-01-2010, 06:47 PM   #5
saph4be
Trader Score: (0)
saph4be is an unknown quantity at this point
Quote:
as said be sure to have the timing pin kit or it will end in tears
and i found on these the bottom pully's are very tight to remove
saph4be is online now   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
