PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 26-01-2010, 10:08 PM   #1
Red_bull
Trader Score: (0)
Red_bull is an unknown quantity at this point
Default Megasquirt ignition setup on CVH EFI
Hello,
I'm quite new to the megasquirt thing and trying to find out some things. I want to buy a Megasquirt 2 with V3. I would like to run a set up without the ford edis system to be fully in control of ignition and be able to run ignition cut for example. I also would like to stay with 1 crank input as that is std on my CVH EFI engine. I have found this in the manual about 1 crank input with two outputs:
M-N toothed wheel comes in on Input 1 and there is no Input 2. The first tooth after the missing tooth starts the firing sequence on Output 1, then fires Output 2 after Skip teeth (= next tach), and alternates thereafter. This option provides 'wasted spark' coil firing for 1, 2 or 4 cylinders. For a 1 or 2 cylinder engine the two outputs must be tied to the single coil.
You can also do 2 or 4 cylinder wasted spark with this crank wheel only option. There are 2 flavors of this: Odd angle = 0 and != 0. The difference is that pure wasted only has one coil - and you have 2 outputs, so you have to tie them both together using a logic OR gate. Or you could ignore one output, but then MegaTune would display double or half the actual rpm. This setup has symmetric inputs and outputs - that is you fire each output every 180 deg and it is even fire. With odd-fire, you have to fire non-symmetrically, so you MUST have 2 separate coils which are fired separately every 180°, with the offset put into Odd Angle.
I have a even fire engine with a 36-1 toothed wheel so till now it looks fine for me..
Also this is in the manual
IMPORTANT! You can directly drive a maximum of one coil per ignition driver with MicroSquirt! This is because the coil driver (the VB921) can only sink enough current for one coil. That one coil can be a double ended 'wasted spark' type coil for two cylinders/coil (ex. the Ford EDIS4 coil pack with each coil driven by a separate driver), and it will be fine. But you CANNOT 'direct drive' two separate coils in wasted spark configuration driven directly off of one ignition driver (see below).
If my english is good enough they mean with ex. = example so my ford coil pack should be fine.
My questions are :
Is this possible with the MS2 and V3? Are there big disadvantages?
What i need to change on the ECU to change it to get the two outputs! Can i fix it in megatune or do i need to change something in the hardware?
Or is it a plug and play like it's displayed on here: http://www.extraefi.co.uk/Drawings/PDF_ ... l_Pack.pdf
I hope somebody can help me, because my english isn't good enough to sort this out on my own and i don't want to start with blowing my ecu or forgetting things in my order...
__________________
" Dream as if you live forever, live as if you die today. "
Check my project on http://passionford.com/forum/restorations-rebuilds-and-projects/207111-big-s2-rs-turbo-project-finished-lots-of-pics.html
Red_bull is offline   Reply With Quote
Old 26-01-2010, 10:12 PM   #2
rich123
Trader Score: (3)
rich123 is on a distinguished road
just leave it running coilpacks the m/s only needs a crank sensor and 36-1 wheel to run its an easy setup
rich123 is offline   Reply With Quote
Old 26-01-2010, 10:20 PM   #3
Red_bull
Trader Score: (0)
Quote:
So it's basicly plug and play like on the link in my first post? Sorry but it's difficult for my to understand your answer
__________________
Check my project on http://passionford.com/forum/showthread.php?t=207111
Old 26-01-2010, 10:37 PM   #4
rich123
Trader Score: (3)
yep plug and play basically
Old 27-01-2010, 04:11 PM   #5
AlexF
AlexF's Avatar
Trader Score: (0)
AlexF is an unknown quantity at this point
Alex Flower
Send a message via MSN to AlexF
just run wasted spark on an MS2 V3 ECU
Alex
__________________
"Judging by the car you have chosen, you are a motorist of a special breed, and you are probably no novice when it comes to automobiles." . . . 928 S4 Owner's Manual 1987
AlexF is offline   Reply With Quote
Old 27-01-2010, 10:25 PM   #6
Red_bull
Trader Score: (0)
Quote:
Alex
That's what i want! I want to run it like this http://www.extraefi.co.uk/Drawings/P..._Coil_Pack.pdf
BUT!! the standard diagram has only one ignition output on 36 and not the output like the pdf says on #6.
So my question is how can i get the ignition output on #6 or is it allready there on the MS2 V3 board?
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
