PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 26-01-2010, 07:30 PM   #1
Burnzybubbles
Bubbles
Burnzybubbles's Avatar
Trader Score: (0)
Burnzybubbles is on a distinguished road
Default symptoms of gearbox syncros wearing out?
as above really i put a post up in the cold spell that my gearbox was being a real pain in the arse to get into 1st and 2nd now it's warmed up a little and i'm still having major problems when the engine is cold to downchange into these gears, i found sometimes double clutching does help but not always, i'v also changed the gearbox oil because i thought it could be that causing it but since changing it it's got worse .
whats peoples thought guy's and thanks for the advice
P.s what grade of oil should be used in the mtx75 gearbox i'll check the bottle but i just used what the motorfactors recommended won't be the first time there computers could be wrong
__________________
mk5 esco dead
Burnzybubbles is offline   Reply With Quote
Old 26-01-2010, 08:29 PM   #2
PeterRST
PeterRST's Avatar
Trader Score: (1)
PeterRST is an unknown quantity at this point
It's a quite common problem with older MT(x)-75 gearboxes in the cold. An oil change might help, not necessarily though. Use specific MT75 gearbox oil as supplied by Carlube and Comma. Don't bother trying your local Ford dealer as they don't stock it anymore.
If you put in normal gearbox oil, I'm not surprised it got worse.
Double clutching on upshifts (+ blipping throttle on downshifts) only helps if you match the revs exactly. With a bit of practice you can learn it.
I wouldn't worry too much as it will get better in warmer weather and the syncro rings will most probably still last many thousand miles until it gets really bad.
PeterRST is offline   Reply With Quote
Old 26-01-2010, 08:31 PM   #3
RichieST
RichieST's Avatar
Trader Score: (2)
RichieST is on a distinguished road
Send a message via MSN to RichieST
Is the clutch ok? How about cable/linkage adjustment? Does it go in and out of gears with engine off?
__________________
RichieST is offline   Reply With Quote
Old 26-01-2010, 08:54 PM   #4
Burnzybubbles
Bubbles
Trader Score: (0)
cheer's peter that's some sound advice and it has comma gear oil in it that's what they advised but it still had an ep rating but it was an unusual one can't remem exactly, and it's getting quite bad whilst cold i just can't get second on the downchange at all and it won't go into 1st till i'v come to a complete stop, after a few minutes it eases still quite notchy though, my clutch is some cheap shite that i thew in whilst i wasn't working to get it on the road.
i might just take a week off and do a box change with a recon and the lower arms, exhaust, valeo clutch or summit with a bit of biting power and brakes, i'm still toying with the idea of making into 4x4 and putting a mk1 4x4 box in but will give it some real consideration before i put my mind to it.
god now i look at it it's making me think of how long it's gunna take esp when i know the only place it's getting done is on the floor at home
and rich yea it's getting the gears whilst at standstill with engine off or on it's a 10,000 mile old clutch albeit a shite ebay one, have noticed it gets hot very easily, it's a hydrolic clutch mech so shouldn't be many prob's there i replaced the csc when i did the clutch, but i did set the linkage myself and always though i'v set it slightly to far to the right a little making 1st and 2nd a bit of a pain to get when cold it does seem quite fine when hot after a long run like going to london.
__________________
mk5 esco dead
Old 26-01-2010, 09:05 PM   #5
dojj
Resident Wrestling Legend
dojj's Avatar
Trader Score: (3)
dojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the rough
if it's worn the brass bits of the syncro tend to wear out and they simply stop grabbing the other part of the gear they mesh into after they've slowed the gears down
change the fluid to see if this solves the problem, and yes, you have to use mtx75 specific fluid, not the stuff ford tell you to put intot he box nowadays as it's wrong
dojj is online now   Reply With Quote
Old 26-01-2010, 09:10 PM   #6
Burnzybubbles
Bubbles
Trader Score: (0)
see i always remem in halfrauds there being "MTX75 gearbox oil" on the shelves and even had a litre here at home from my old man but just never seem to see it about, i went into halfrauds for some oil and he brought out some hydrolic auto fluid
__________________
mk5 esco dead
Old 26-01-2010, 09:34 PM   #7
PeterRST
PeterRST's Avatar
Trader Score: (1)
Euro Car Parts still sell it:
http://www.eurocarparts.com/ecp/c/Fo...6d67271a3&TRLU
Changing to that should help as it's much thinner than regular gear oil (similar to ATF).
Old 26-01-2010, 10:34 PM   #8
Burnzybubbles
Bubbles
Trader Score: (0)
cheer's for that peter i'll order some as soon as i get paid hopefully stops it being such a pain in the arse
__________________
mk5 esco dead
Old 27-01-2010, 09:10 AM   #9
utternutter
Trader Score: (0)
utternutter is an unknown quantity at this point
same as the transits, when cold if wrong oil hard to put into first second, i put mt75 in mine and was sweet, i allways bung some molyslip in there too, diff too
utternutter is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
