| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
what car? if valves are bent you maybe losing compression
__________________
![]() BREAKING MY ZETEC TURBO ESCORT!!! MK1 Escort wanted!!! |
#3 |
lol
#4 |
if valves are gone then NO it wont fire up.
#5 |
oh and step away from the vehicle as you have no business being anywhere under a bonnet with youre lack of knowledge
#6 |
It Wasnt Me!
Were all assuming he timed it up properly.....
#7 |
3-door moonstone
Mine snapped 16 valves and a £2000 rebuild later good as new
__________________
The project begins (moonstone 3-door) |
#8 |
#9 |
YES I KNOW I CANT SPELL
lol if you belt snaped and has bent your valves the pistons will be coming up in your cilinders on there compression stroke but wont be compressing any think as it will be leaking out through the belt valves.......... thats if a valve head isent stuck in your piston
__________________
" im special,, excuse my spellings" |
#10 |
3-door moonstone
Get it apart and checked over, it will only bight you in the arse if you dont do it properly now
__________________
#11 |
If the belt has snaped i would imagine you have done more damage! And merley replacing the belt wont fix it
Time to get that wallet back out chap!
__________________
![]() 330cd convertible on the way. |
#12 |
[quote=vroooom ptssssh;4678068]Were all assuming he timed it up properly.....
[/quoteYes haynes |
#13 |
snapped belt = bent valves and piston crowns at the least grazed.
deffo need to strip the engine.
__________________
wanted fez EFi Flywheel/cps sensor |
#14 |
As said assuming it's timed up correctly, it would have no doubt damaged valves when it snapped. You would know if was incorrectly timed would have thought by the noise when turning over. If valves are damaged engine will have no compression and so will not start.
Martin |
#15 |
B1mbo
if you are going to replace valves then make sure you check the valve guides arnt cracked round the bottom
also make sure the pistons arnt marked too bad we had a yb come in with a snapped cambelt and it done the head pistons everything so get it to bits fella unfortunately get stuck there is plenty of us who will help amongst the piss takers lol jim
__________________
![]() mt-motorsport.com
| Display Modes | |
