PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-01-2010, 06:06 PM   #1
jolly
Trader Score: (0)
jolly is on a distinguished road
Default bmw e36 325i straight 6 overheating?????
ive just baught a 325i as a daily user to keep my blue oval out of the shit weather,
the car overheated ( turned the car off within seconds of light coming on ) as i got stuck in some snow outside the house, so i checked for mayo and nothing as i thought headgasket, checked the water pump and it was knackered so replaced that and the thermostat, car stil overheats, so i thought dodgy thermostat so changed it again, stil overheats but no mayo, so i then run the car without the thermostat in and stil overheats, also the pipe from the engine returning to the radiator was cold and should be quite warm / hot, no water circulating the in the system
so i thought airlock so i flushed the car with water and all flows fine, put it all back together and it seemed ok, car was gettin warm inside, the return pipe was hot so the thermostat is working and water is flowing, had the bleedscrew open ( header tank cap on) on the rad for a good amout of time to get rid of any air, shut the bleedscrew and left the car over 2 hours and was fine temp styed bang on in the center then i went out and it boiled again, checked for mayo again and still no trace
also i thought the viscous fan but it seems ok but shouldnt need it in this weather anyway
now im in a pickle as i dont hav a clue what could be rong, im thinkin it could be a majour airlock or headgasket,
any ideas???????????? cheeRS
jolly is offline   Reply With Quote
Old 21-01-2010, 06:18 PM   #2
Ad4m RST
Jiu Boxu
Ad4m RST's Avatar
Trader Score: (0)
Ad4m RST is an unknown quantity at this point
Adam Lux
Send a message via MSN to Ad4m RST
Sounds like you've covered most of your bases....could radiator be fucked? or blocked?
__________________
Vettelian State...!!
My RST's
My MMA & Drift Series'
My MMA HL's in HD
Ad4m RST is offline   Reply With Quote
Old 21-01-2010, 06:27 PM   #3
Escy
Trader Score: (0)
Escy is an unknown quantity at this point
Send a message via MSN to Escy
I'd look at it being an airlock again. I had major problems bleeding my brothers Z3 1.8. It would keep pressurising, must have bled it about 10 times before it stopped over heating.
There is a guide on here, http://www.pelicanparts.com/bmw/tech...lant-Flush.htm
Escy is offline   Reply With Quote
Old 21-01-2010, 06:27 PM   #4
thebigyin
Trader Score: (0)
thebigyin is an unknown quantity at this point
these can be awkward to bleed, sometimes need pressure to do it, or just blow into header tank.
thebigyin is offline   Reply With Quote
Old 21-01-2010, 06:27 PM   #5
jolly
Trader Score: (0)
i doubt it because it was fine before it overheated / water pump broke, on the motorway it diddnt even hit halfway on the guage and round town it was on half as normal
Old 21-01-2010, 06:28 PM   #6
Escy
Trader Score: (0)
The header tank is built into the side of the rad which makes it all the more of a pain in the arse.
Old 21-01-2010, 06:30 PM   #7
jolly
Trader Score: (0)
cheers, have to keep tryin it
Old 21-01-2010, 06:31 PM   #8
thebigyin
Trader Score: (0)
yep
Old 21-01-2010, 06:32 PM   #9
jolly
Trader Score: (0)
Quote:
like get an airline onto the header tank blow air into it and open the bleedvalve??
Old 21-01-2010, 06:46 PM   #10
thebigyin
Trader Score: (0)
Quote:
worst case you would maybe need to pressure bleed, i have done lots of these and the stubborn ones usually bleed ok by blowing into header with the bleeder open, sometimes you have to lift the rad/header a bit above the rest of the system to get it to go.
Old 21-01-2010, 06:59 PM   #11
murfs frst
murfs frst's Avatar
Trader Score: (0)
murfs frst is an unknown quantity at this point
they are a pain in the arse to bleed
__________________
ford fiesta rs turbo
honda civic type r
If it dont fit dont force it.......
murfs frst is offline   Reply With Quote
Old 21-01-2010, 06:59 PM   #12
jolly
Trader Score: (0)
cheers, i must be halfway there as its ok standing still, its just on the moove it does it, cheeRS!!
Old 21-01-2010, 07:02 PM   #13
LHD220Turbo
Trader Score: (3)
LHD220Turbo is on a distinguished road
i'd get a fluid tester to be safe its not head gasket, but when i dont the water pump on mine; it took me well over an hour to bleed the fucker
__________________
www.paintballmasksonline.com
LHD220Turbo is offline   Reply With Quote
Old 21-01-2010, 07:06 PM   #14
jolly
Trader Score: (0)
Quote:
how did u bleed yours, did you just leave it running with water cap on and bleep valve open?
Old 21-01-2010, 07:12 PM   #15
Rax
Rax's Avatar
Trader Score: (1)
Rax is on a distinguished road
carla1212
Send a message via MSN to Rax
Took me about half an hour to bleed my e34,pain in the ass.If I remember isnt there a bleed point on the rad,one for the stat and one for the head ?.Did you have the head pressure tested ? mine had a hairline crack from one end to the other.Common problem due to the waterpump failing.My impeller was the size of a 2p coin .I bought mine as a non runner,when I pulled the head off it had been run that hot as two valve seats were dislodged .
__________________
4wd ?,no al never turn to the darkside
Rax is offline   Reply With Quote
Old 21-01-2010, 07:13 PM   #16
LHD220Turbo
Trader Score: (3)
left it running, cap on with the little plastic bleed screw undone, occasionaly give the engine a good rev - i thought it was done after 40 minutes then another load of air came out when i revved it. they are a pain to do
having said that, another friend had a 323i and his overheats every 4/5 months, he has never got to the bottom of it - he's done everything you've done!! he just bleeds it again and its fine for a few months.
the only thing i suggested to him was it might be a problem with the heater matrix, that's the only thing left!!
__________________
Old 21-01-2010, 07:20 PM   #17
jolly
Trader Score: (0)
thats what i was doin, so basically keep doin it till all the steam / air has cleared?
Old 21-01-2010, 07:23 PM   #18
jolly
Trader Score: (0)
Quote:
not sure about the one for the stat or head but theres one on the rad that i have been using, no not had it tested yet, yea my impellar was the same, the whole thing had come off, now replaced it with i metal item
Old 21-01-2010, 07:25 PM   #19
Ellie
Ellie's Avatar
Trader Score: (0)
Ellie will become famous soon enough
Send a message via MSN to Ellie
Water pump went on my mr2 the other week, probably due to the core plug (whatever one of them is, its in the head apparently) leaking, lost enough coolant to seize the pump. Heater was still blowing hot and the temp guage stayed normal but i saw steam in my rearview mirror, and it was coming from the bottom of the engine and not the header tank.
Mine is also a bitch to bleed so it was left on ramps lifting one end of the car up (dont know which end, header tank in the back but radiator is at the front along with the bleed valve) and that seemed to do the trick.
__________________
Ellie is offline   Reply With Quote
Old 21-01-2010, 07:30 PM   #20
rspickup
Trader Score: (0)
rspickup is on a distinguished road
I just had same problem with my one! they are a bitch to bleed out, they need to be cold, remove bleed screw near cap, engine off, fill up slowly, watching the air disperse from bleed nipple! keep going slowly, leave a few minutes, and fill again, even if expansion tank is overflowing, when water runs clear put cap on and do up fooking tight!
Dont worry about expansion level it has to be up to the brim, start it up, heaters whacked on full and let it run, the expansion level will sort itself out so dont worry and providing air is all out it should be sweet.
__________________
rspickup is offline   Reply With Quote
Old 21-01-2010, 07:33 PM   #21
Rax
Rax's Avatar
Trader Score: (1)
carla1212
I dont think you will do it just from the rad tbh.I am sure there is one for the stat and another for the head.I think they were a nut with a copper washer underneath.Post a picture up.I ended up buying a 325 and taking the head off,stupid thing to do but I couldnt find one or anyone who guarantee me a good one.
__________________
Old 21-01-2010, 07:37 PM   #22
jolly
Trader Score: (0)
ar rite i thought it had to be warm, so just force water through it forcing the air out until water flows freely and continuous through the bleed nipple, will it stil bleep tho as the thermostat wont be opening?? cheeRS, nice pikup by the way i had that idea of doin a s1 pikup the other day when i found a mk3 escort estate for sale
Old 21-01-2010, 07:37 PM   #23
rspickup
Trader Score: (0)
My worshop is next to a bmw specialists, thats how they told me to do it, and it worked, spot on, they told me DONT touch the others.
__________________
Old 21-01-2010, 07:41 PM   #24
jolly
Trader Score: (0)
ok pal ill try that, hopefully should do the trick, cheeRS mate
Old 21-01-2010, 08:04 PM   #25
BM08
BM08's Avatar
Trader Score: (0)
BM08 is on a distinguished road
Not read all the replys but when i had a 323 it was a airlock which caused it to overheat, it was last summer one evening when it was pretty sticky weather, so i thought it was the heat that caused it.
It still ran fine after it was fixed, good job it wasnt a ford engine or it would have been totally goosed
BM08 is offline   Reply With Quote
Old 21-01-2010, 08:19 PM   #26
jolly
Trader Score: (0)
that is very true haha
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
