| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
![]() Mapped by Jamie@Evotune 1.7 bar@ 366 Bhp and 360Torques |
#2 |
![]() BANNED |
Easy enough to do, the dayco kits are very good vfm, and decent quality.
Make sure you get a kit with everything needed and not just the belt though. Don't overtighten when doing things up as these do seem to strip threads easy, unless I was just unlucky. tabetha |
#3 |
How much mechanic experience do you have mate? I don't want to teach you to suck eggs kind of thing.
They'er quite simple though tbh, alternator, engine mount and bracket off, 10mm blanking bolt is on the belt end of the engine, at the back near the driveshaft support bearing. Floating crank so it's essential you lock the crank off, and just turn the engine over plenty of times and check the timing before you put it back together. Any questions just ask mate. |
#4 |
Crank pulley bolt can be extremely tight, you will struggle unless you have Air tools and a decent compresser.
With any cambelt, mark up manufacturers marks, and make up your own marks, check check and check again. NB, replace the Tensioner also, as its these that tend to fail, not the belt |
#5 |
thanks for that, ive got a dayco kit on my evo and not alot of people now dayco make the oem belt for farrari,s
__________________
#6 |
Resident Wrestling Legend
tensioner is a must
__________________
![]() Winner: Best Thread on Passionford 2007 How to Quickshift an MT75 Box don't forget i'm dyslexic peeps winning potatoes |
#7 |
is there not a secial tool nneded to remove the pulley?
__________________
#8 |
pully puller?
might be
__________________
#9 |
Trader Score: (1)
Rep Power: 33 ![]() |
you have to remove the cam cover and lock the cams off. My wifes fiestas t belt needs doing. I would like to have a go myself but i dont like doing t belts.
#10 |
Trader Score: (1)
a lad i work with said you can cut the t belt cover to remove the belt and then you dont have to remove the bottom pulley.
#11 |
YES I KNOW I CANT SPELL
__________________
" im special,, excuse my spellings" |
#12 |
#13 |
__________________
2WD Sapphire |
#14 |
Testing the future
miy '96 needs doing as well as it's now up to 130,000 miles, but for the cost of parts and the time and hassle it's not worth it. i only paid Ł90 for the car 5 years ago
thrash it 'til it dies is my motto, although i did stop this morning when i could smell oil and lifted the bonnet to find i had left the 710 cap off after topping it up on sunday
__________________
Nick It takes me less than 9 minutes ![]() RP Lab L8 ECU 1998 Puma 1.7 / 2002 Galaxy 2.3 LPG / 2007 Honda VFR800 VTEC / 1972 Honda C90 |
#15 |
you need a flat bar to lock the cams off and a peg to lock the crank. you need to make sure that the bolts are very very tight as the crank and cams have no keyway and just spin if not tightened up ive seen loads of people bend all the valves in the head..
#16 | |
Quote:
thats my theory, i'd rather change an engine than a cambelt so let it go
__________________
#17 |
competant bodger
easy enough to do if you have enough experience like mentioned above make sure you lock the crank and beware when locked it only stops it turning clockwise but will turn anti clockwise so check check and check again, and if you do cock the timing up dont try to set it to top dead centre on no1 as these time up quite a few degrees before tdc, however if you do time them at tdc they will still run just wont tick over!!!!
#18 |
__________________
#19 |
i wouldent trust a cambelt to 100k no fucking way, even though that is the recommended interval. alwys change mine early to be on the safe side
as said make sure you lock the crank!!!! and a spot of locktite on the bottom pulley when it goes back on fooking TIGHT
__________________
Ebony Black 4x4 Saph Cosworth Resto |
#20 |
Trader Score: (1)
#21 |
Trader Score: (1)
#22 |
Trader Score: (1)
anyone wanna come and do the wifes fiesta. I dont mind paying. I just dont like doing timing belts.
#23 |
Trader Score: (1)
#24 |
Ford for life
the tensioners should be changed at about 60k though and if anyone just changes the one or the other needs shooting
#25 |
the amount of focus's and fiestas etc that have let go before 100k i have recovered i couldnt even recal but its a helll of a lot
#26 |
as said its the shit quality tensioner pulleys that let go so often
__________________
#27 | |
Quote:
![]() even cam chains, if they are easy enough to do i'd rather thange them after 100k or so rather than lob in a new engine
__________________
| Display Modes | |
