| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
ps, its a 55 plate 6 speed
#3 |
the best 4x4xfar
i did 2 ov these and both were a nightmare. and it ended up bein the slave on the pedal aswell as the 1 in the box but mine was a slightly different problem to yours it was in every gear. it was ok 4 a couple ov days then started playing up.
__________________
[/SIGPIC][/SIGPIC] Xbox live id....... C2SSV SPROUT |
#4 | |
Quote:
COSTLY BILL MATE MINE WENTS LAST YER 1700QUID FOR REFURBED GEAR BOX AN NEW CLUTCH +SLAVE CYLINDERS ,ITS A FAULT ON THEM BEARINGS GO
__________________
loysport http://www.bafabrications.co.uk/ PM MONSTER FOR CUSTOM VIN TAGS carpartsexpress mail order ford parts 01914272186 Last edited by dingla rs; 17-01-2010 at 10:15 AM. |
#5 |
whats is it with gearboxs on those vans, i look at the price of salvage ones they make fooking loads, so spose the engines are worth money too which means they also must go for a past time
#6 | |
if in doubt flat out
Quote:
gear boxes are shit that why the bearings go bloke that did mine showed me bearings they use plastic compared to ones he put in ,wouldnt buy second hand one tho probly have same problem |
#7 |
i had one of these vans for 2 weeks and learnt my lesson, bought a 05 toyota hiace not quick but given me no trouble, the amount of these vans for sale with gearbox faults, surely vauxhall should of did a recall.
Pete |
#8 |
did the clip come out at all that adjusts the length of the gear cables? Had the same problem in the past and that was the cause.
#9 |
as for the oil, they spec a 75/80 grade. Fitted more gearboxes to those vans than i care to remember!
#10 |
on a van buily by renault, terrible vans, worked at a vaux dealership and they caused major trouble, very unreliable
#11 |
you havent filled the gearbox to the level of the fill bung have you, sounds the same as what i did made the gearbox very tight, dain it out and put in 2.6 ltrs of 75w/80w.
but as said above have also changed the clutch master cylinder and the gearboxs do shit them selfs quite often.
__________________
![]() B ^^^ RANGE ROVER P38 2.5 DSE ^^^^
#12 |
Ive done three clutches now and each time ive had to change the master cylinder on the pedal.
Just make sure if you do another to change it all, clutch, concentric and master cant go wrong then. Ł24 for the master cylinder from vauxhall so no big deal. Crap van imo, we have had atleast 4 in broken down with crank sensor wiring faults too.
__________________
#13 |
whilst the discussion about these vans are here, anyone know why my pals one wont rev if the cluth is pressed in then revs freely when in neutral at idle. He cant pull away without 'slippin the clutch' but wil cruise like nothings wrong when it gets its speed up. Its very dangerous at pullin away , gearbox works fine !!!
#14 | |
Quote:
as for the gearbox i put a 80 weight oil in and 2.6l so i think that was alright cheers all for your replies, and yeah these vans are shite; people buy them because they are quite nice to drive |
#15 |
no more Granada's for me
I picked up numerous vivaros with fucked gearboxes when i did recovery, they just lock up. mostly had to use skates to get then off the truck and in the dealer.. they seem to only last about 60 to 80 thousand mile
__________________
#16 | |
Quote:
Dont know why but my old transit and my current expert both do it as well, wont rev over 3k with the clutch pushed in, wonder if its to save the clutch to much abuse (i.e. fit cheaper clucthes as standard)? |
#17 |
did they struggle to pull away ? its a good point tho m8
#18 |
very common fault on these sheds is as follows:
fuelling problems air mass meter fuel regulators fuel pumps crank sensor wiring list is endless. |
#19 |
It's to stop people abusing the fuck out of them and fucking the DMF usually, a rev limit of 3000 rpm so people cant do 5000rpm launches.
#20 |
they newer ones dont suffer from bearing problems anymore!does the pedal feel ok mate?
__________________
![]() 416.1bhp STORMTROOPER I am the real doug! |
#21 |
Trader Score: (1)
Rep Power: 33 ![]() |
we are getting some of these vans at work. I dont think i wanna work on them now.
#22 |
#23 |
Work mate has a Nissan, Went looking for a door trim for the passenger door. Main dealer wanted €170!! Went to an opel (Vauxhall) dealer and got it for €29 !!! The dealer either fooked up or else go to vauxhall for all your parts!
__________________
![]() CheeRS Alan. |
| Display Modes | |
