PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 16-01-2010, 10:58 PM   #1
Paulo P
Paulo P's Avatar
Trader Score: (0)
Paulo P is on a distinguished road
Default How do you stop windscreen wipers juddering?
The windscreen wipers on my ST have started juddering over the windscreen and it's very annoying, is it due to angle the blade is on the screen or does it need new blades? I always thought it was due to the angle of the blade but I want to fix it now.
Anyone know?
Thanks
__________________
Paulo P is offline   Reply With Quote
Old 16-01-2010, 11:00 PM   #2
LHD220Turbo
Trader Score: (3)
LHD220Turbo is on a distinguished road
i found this with shitty blades, but also try cleaning the screen with autoglym super resin polish - you'll be amazed at the difference
__________________
www.paintballmasksonline.com
LHD220Turbo is offline   Reply With Quote
Old 16-01-2010, 11:02 PM   #3
Paulo P
Paulo P's Avatar
Trader Score: (0)
The car is due a clean so I'll give that a go thanks, it's been worse since all of this snow
__________________
Old 16-01-2010, 11:03 PM   #4
BM08
BM08's Avatar
Trader Score: (0)
BM08 is on a distinguished road
Think its crap blades mostly, i spent about £15-20 on my last set as opposed to £5-10 which you can get, and mine are silent, only time they judder slightly or make a sound is when i accidently wipe a dry screen.
Also last week i used super resin polish on the inside of the windows, and it works fantastic, the glass looks so clean and feels very smooth not tried on the outside though? would it not make the screen go weird when it rains?
BM08 is offline   Reply With Quote
Old 16-01-2010, 11:08 PM   #5
LHD220Turbo
Trader Score: (3)
dunno; when i did it, it got rid of every last bit of dirt, it was squeaky clean - i washed the screen afterwards and it seemed fine
__________________
Old 16-01-2010, 11:12 PM   #6
Rick Astley
Never gonna give you up!
Rick Astley's Avatar
Trader Score: (0)
Rick Astley is on a distinguished road
Don't forget to wipe the actual blade itself. Vinegar is very good for this as a quick fix. i.e. throw abit on some kitchen towel and wipe over until glossy.
Rick Astley is offline   Reply With Quote
Old 16-01-2010, 11:12 PM   #7
S1rst
Trader Score: (0)
S1rst is an unknown quantity at this point
Get some rain-x. Its brilliant stuff and your wipers should then be silky smooth. Re-apply every time you clean the car and job done.
__________________
S1rst is offline   Reply With Quote
Old 16-01-2010, 11:20 PM   #8
botters
competant bodger
botters's Avatar
Trader Score: (0)
botters will become famous soon enough
i once polished the outside of the screen on an old mk5 escort van i had and wished i hadnt instantly due to there being hundreds of minor stonechips in the window leaving me with hundreds of little white spots on my window lol!
botters is offline   Reply With Quote
Old 16-01-2010, 11:25 PM   #9
Paulo P
Paulo P's Avatar
Trader Score: (0)
Thanks for the tips Hopefully I can sort it tomorrow.
__________________
Old 16-01-2010, 11:42 PM   #10
FletchCossie
Trader Score: (3)
FletchCossie is on a distinguished road
I used to polish my windscreen, but when it started raining it smeared and I could hardly see out the screen till it wiped the polish off.
Your window is dirty as said above. Use some good cleaning stuff (Like Mcguires, not fairy liquid ) and you should be ok. Make sure you use screen wash also, not just water You may wanna replace these blades tho...
Cheap ones always caused me problems. On the Skoda I changed blades 4 times in a year and they were still shit, even different makes. but I brought genuine VW Aero Blades (Inc wiper arms from a Mk4 Golf) and I haven't changed blades in over a year
My Esc Cos has genuine Ford ones Wish I could change these to aero blade ones also (genuine ones, not the modified ones to fit any car)
__________________
FletchCossie is offline   Reply With Quote
Old 16-01-2010, 11:50 PM   #11
Paulo P
Paulo P's Avatar
Trader Score: (0)
If I'm honest the car needs a damn good clean so I will go and get some autoglym window cleaner because it does a great job. The windows are filthy inside and out and the car needs a good going over now the snow has gone.
I don't know how old the blades are of if they are genuine ones, the car is just over 3 years old now.
__________________
Old 17-01-2010, 07:45 PM   #12
Trader Score: (0)
tabetha will become famous soon enough
Newspaper is the best stuff to clean your screen with, wet obviously, that's what I use.
It's the angle of the blade that causes juddering, they need to always trail the arm, ie when the blades goes one way it leaves the blade in a trailing fashion, when it has done the full sweep and is about to go the other way the arm reversing causes the blade to flip over, just watch closely and you'll see.
As the rubber gets old and hard it no longer wants to flip over as it should, so gets pushed instead of pulled by the arm, this will always cause juddering, sometimes the arm just needs a slight tweak so that the blade sits at 90 degrees to the screen so it can flip each way as needed no problem.
tabetha is offline   Reply With Quote
Old 17-01-2010, 08:00 PM   #13
Ginge !
just finding my feet
Ginge !'s Avatar
Trader Score: (0)
Ginge ! is on a distinguished road
Quote:
thats for windows WITH NO WIPERS such as side windows and mirrors,,, not for a front screen mate
__________________
Quote:
Originally Posted by zetec-Sam View Post
Just think 'what would Charlie Sheen do?'
Ginge ! is offline   Reply With Quote
Old 17-01-2010, 08:05 PM   #14
Ginge !
Ginge !'s Avatar
Trader Score: (0)
ive got aeroblades on the scoobie, i dont get any squeel but the screen aint "clean" as in when theres lights on the screen you can see dirt marks,,,, and i cant get rid of em with glass polish,,,, anyone recomend as the other alternative is my windscreen cover and pay the excess ( which i will be doing soon as it pisses me off the marks)
when its dark and light rain or just dark on motorways sometimes its a struggle to see infront,,,, im having to slow down to as low as 100mph sometimes crawl at 90 !!!
__________________
Old 17-01-2010, 08:16 PM   #15
S1rst
Trader Score: (0)
Quote:
Im pretty sure its for any glass mate, inside and out. In fact i think its actually designed for windscreens primarily. Used it on all my cars with excellent results. Also prevents steamy windows on the inside and makes the wipers run silky smooth. It makes them so smooth that the windows feel like glass.
Having said that, i dont use it on the escos because its not needed as the centre of my windscreen hasnt even seen a wiper for about 10 years at least.
__________________
Old 17-01-2010, 08:20 PM   #16
Ginge !
Ginge !'s Avatar
Trader Score: (0)
your thinking of the other stuff, rainx is for letting rain flow quicker,,,, but the wipers clean it off the screen and can cause smudging
__________________
Old 17-01-2010, 08:22 PM   #17
KSA-Cossie
KSA-Cossie's Avatar
Trader Score: (2)
KSA-Cossie is on a distinguished road
Send a message via MSN to KSA-Cossie
PIAA blades you want m8. Rain x is for windscreens.
__________________
cheeRS kev
R/B T38,siemens blacks,500 intercooler,MSD closed loop,wasted spark,18" MO's,362mm discs,AP 6 pots,ALS & LC.
Motorsport Developments 01253 508400
KSA-Cossie is offline   Reply With Quote
Old 17-01-2010, 08:22 PM   #18
RUPERT THE BIG HAIRY BEAR
Trader Score: (0)
RUPERT THE BIG HAIRY BEAR is on a distinguished road
alain rupert fitton
i got some genuine ford aero baldes for my fez st they were absolutly awesome but my mates trying to find them for his connect and carnt
also i wax the front window well all the windows in my cars i use autoglym same stuff as i use on the body if u use that and do a good job u dont need window wipers as it just slides of with the glass being so smoth
RUPERT THE BIG HAIRY BEAR is offline   Reply With Quote
Old 17-01-2010, 08:24 PM   #19
GAZ W
Trader Score: (0)
GAZ W is an unknown quantity at this point
Send a message via MSN to GAZ W
Ive got pound shop specials on my fiesta and they work perfectly well
__________________
GAZ W is offline   Reply With Quote
Old 17-01-2010, 08:28 PM   #20
Brian
Trader Score: (2)
Brian is an unknown quantity at this point
When ever i clean our cars i always use Auto Glym window cleaner and clean the windows and also use it on the wiper blades and never have any prob's
Brian
__________________
Brian is offline   Reply With Quote
Old 03-05-2011, 12:47 PM   #21
plums
Trader Score: (0)
plums is an unknown quantity at this point
Hi all. Late reply but i was looking for a cure for a juddering rear blade. It's been a pain in the backside (sorry for the pun)for years but after reading through some forums i came to the conclusion that its the angle of the blade. I've just given mine a twist with a rag and pliers and the blade runs lovely even when the window is bone dry. Nice 1! Thanks tabetha
plums is offline   Reply With Quote
Old 03-05-2011, 04:15 PM   #22
KSA-Cossie
KSA-Cossie's Avatar
Trader Score: (2)
Brilliant stuff.
__________________
cheeRS kev
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
